Throttle assembly, need help!
- AJCrader
16 Aug 2006 19:49
I was wondering if there are any good aftermarket throttle assemblies for a dual cable setup? All I can fid are sing cable, and being that i'm building a drag bike, I like the idea of being able to close the carbs with the throttle, any help or point in the right direction would help....
AJ
Drag bike, 1220cc Z1R KZ project
- RomSpaceKnight
Re: Throttle assembly, need help!
16 Aug 2006 20:14
I you do find one, try to get a 1/4 turn throttle. Makes it easier to launch.
- mikekz900
17 Aug 2006 07:15
www.pmfronline.com
I'm still checking on that swingarm. Pmfr stuff is pretty tough. Been very happy with them so far.
- AJCrader
17 Aug 2006 08:12
They are $400?!?!?! isn't that a lot? I found an old triumph 7/8" dual cable on ebay for like $23 so far(just found out it is dual pull). Is it because its billet or something? i'm a bit lost
would it make much difference to use just one cable? I'm all about being as safe as possible, I could always rig up something to pull just in case right? I just can't seem to find something that is clean enought to replace it.
Post edited by: AJCrader, at: 2006/08/17 12:31
AJ
- mariozappa
17 Aug 2006 10:36
Depending on what you have left on your 650, you carbs (if they're VM24's) should have a huge spring to make the throttle return to it's original position, the return cable seems to be almost overkill, but you know what they say...safety first.
FWIW, when I put some CV34's on my bike, they did not have a return cable, but had return spring and it seemed to work fine.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- AJCrader
17 Aug 2006 11:26
to be honest i have no clue what carbs are on it, but they seem to be stock, and yes there is a huge return spring on there, I guess i should just go by the cycle shop by me and look at what they have for comparison to what I have seen on here
AJ
- mariozappa
17 Aug 2006 11:52
I believe the should be the stock ones
kzrider.com/media/kunena/attachments/leg...s/VM24ebay_front.jpg
Stolen picture from WG in another thread.
1977 KZ650C1
- AJCrader
17 Aug 2006 12:54
Thats them alright, having a hard time getting them off as it is, but i did find a thread with ideas on it, are there better carbs i should look for? or is there not much difference?
AJ
- donthekawguy
18 Aug 2006 01:18
You cuold leave the kill switch on it. At any track there is ample room to freak out, poop yourself then think, hey I have a kill switch.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
