Tube size?
  • dkmk
  • dkmk's Avatar Topic Author
Tube size?
11 Aug 2006 02:03
#68676
I am in the fortunate position of having to change the tube on my rear tire. Original tire was a 110/90-18, but had switched to a 130/80-18. I had picked up a tube to fit the newer tire, but having a hard time getting it to sit properly inside the tire without creasing in one spot.
Should I be using a different size tube? Thoughts and input greatly appreciated, as the riding season is slowly running out and the snow will be flying soon! :laugh:
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
  • fixer5000
  • fixer5000's Avatar
Re: Tube size?
11 Aug 2006 05:18
#68692
are you blowing up the tube slightly before you try to install it?? it will stay straight that way. and keep you from pinching it while mounting...steve
1978 kz650b pretty much stock
massachusetts
  • dkmk
Re: Tube size?
11 Aug 2006 08:20
#68726
Thanks, Steve. Actually, I installed the tube first, then inflated it slightly and adjusted it accordingly to get it to sit properly on the rim. It is quite possible I pinched the first one even though I tried to be careful. Luckily I bought a second tube for a spare.
I suppose I am also looking for some clarification regarding the tube size which should be used. Do I use a tube to match tire size, in this case the 130, or use the narrower tube to match the rim. Thanks again.
Northern Ontario
  • mariozappa
  • mariozappa's Avatar
Re: Tube size?
11 Aug 2006 08:39
#68730
You should be OK going from 110 to 130 with that tube.
Rear tube should be 18 inches 4.00/4.50. Can't remeber the metric version off the top of my head.
:whistle:
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • dkmk
Re: Tube size?
11 Aug 2006 09:03
#68735
MZ, the tubes I picked up were 18 - 4.5 to 5.10 which is what the parts guy at one of the local shops recommended. Potential problem there? Thanks for the input.
Northern Ontario
  • mariozappa
Re: Tube size?
11 Aug 2006 10:00
#68750
I think you should be fine. The reason I mentioned that certain size was that it was what I used on my rear tire when I changed it a couple of days ago.
I'm no expert,so if I'm wrong, somebody will jump in and say so.
I believe my 77 kz650 has a 4 inch wide rim, that tube was 4.00/4.50.
I don't think yours is a different size.
1977 KZ650C1
  • RonKZ650
  • RonKZ650's Avatar
Re: Tube size?
11 Aug 2006 12:12
#68784
I think a 4.50-5.10 will fit, but that is a rather large piece of rubber to squash in your tire. You'd be better staying with the smaller tube. Tube size is not critical. Of course you don't want to run a 1" wide tube in a 8" wide tire, that's a given, but slight size variations in tires vs. tubes are no problem. In a pinch I've even used 18" tubes in 19" wheels and vice/versa. Not by the book, but never a problem.
  • dkmk
Re: Tube size?
12 Aug 2006 14:44
#68994
Just a follow up for future reference. Exchanged the 4.5 - 5.1 for the 4.0 - 4.5. Fit like a duck's heel in the mud! <Willie Nelson singing On The Road Again........> B)
Northern Ontario
  • mariozappa
Re: Tube size?
14 Aug 2006 05:06
#69260
Great, now hurry up and GO RIDE!!!
1977 KZ650C1
