Help? Which extended swing arm?
- AJCrader
09 Aug 2006 10:04
I have a 78 KZ650, and want the extended are, but i have no febricating skills, are there any kits that would just bolt in and give at least 4 inches? I also want to lower the rear too, any ideas?
I searched through the forums, but wasn't able to find anything.
Post edited by: AJCrader, at: 2006/08/10 08:33
AJ
Drag bike, 1220cc Z1R KZ project
- AJCrader
Re: Help? Which extended swing arm?
11 Aug 2006 07:07
can anyone help me?
AJ
- RomSpaceKnight
14 Aug 2006 17:18
900/1000 more popular for drag racing. Extended swing arms not a standard project for 650's. Find out how wide your arm is at the pivot point. Then try to find out what swing arms will fit. Try older GSXR and 750 triples.
- timber
14 Aug 2006 18:05
if all you want is a bolt it up and go kit. nope, if you want to do a little creative work you can make some other swing arms fit. sorry there just isnt a swing arm extenion kit like they make for the newer street rockets.
- RomSpaceKnight
14 Aug 2006 18:16
I would look for a 750 triple swingarm. Is 3" longer than the 900's and not near as wide at the pivot point. You will need to come up with spacers probably. TRy e-bay or a bike wrecker.
- AJCrader
14 Aug 2006 18:56
You said a 750 triple, whats funny is i almost had a mechanically sound one for $1500, but looked ugly...are there any particular years of the 750 triple, or just any?
AJ
- 77KZ650
14 Aug 2006 18:56
the kz1000 arm fits, and the gs1100 arm fits, both are longer than the 650 arm, i have also seen lowering links on 1000s that move the shock mounts back, also try shorter shocks, ive been told that stock HD shocks work well and can be picked up off of ebay cheaply
07 MDP Rookie of the Year
- AJCrader
14 Aug 2006 19:30
should I try to go with a disc setup or sstay with drum, or does it really not matter?
AJ
- RomSpaceKnight
14 Aug 2006 19:37
If your fab skills are under developed stay with drum. Gs swingarms are good, square section and stronger. Struts will lower your rear end you won't need to botherwith lowering kits.
- AJCrader
14 Aug 2006 19:40
I guess I should probably ask a few of the guys that run at the track i work at, if they might be able to help me out. lol, maybe i should have mentioned i work at a drag strip
AJ
- mikekz900
15 Aug 2006 13:58
If you are going to a lot wider rim or 180-200 tire then I suggest going with a disc (little fab but less trouble in the end). If you are going a little wider tire like 130-160 on stock rim I would stay with drum. As far as braking I've ridden both and although the disc is a little better it was not that much better. That's why I stayed with drum. But kind of a pain in the butt trying to make work in the end.
- mikekz900
15 Aug 2006 14:05
Actually I had a 3 or 4inch over arm made for my drum brake 79kz650 about 3 years ago it's still at the machine shop. If you are interested maybe we can work something out. We actually forgot about it till the other day when I was talking to him on the phone and he said hey you remember that swingarm thing and I was like oh yea.
It was made to fit the stock width pivot point so no spacers would be needed. Just a exact bolt on. He also does very nice work. Pm if interested.
Mike
Mike
