Brake question.
  • kzmarvo
  • kzmarvo's Avatar Topic Author
Brake question.
05 Aug 2006 22:40
#67405
Can i take the front disk brake off the front of my 76 900 and bolt it on the other side? I know the caliper wont go out the other side i just wanna see if the disk brake will fit the other side.
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
  • fixer5000
  • fixer5000's Avatar
Re: Brake question.
06 Aug 2006 04:05
#67433
it most likely will bolt right on there...now find that other caliper...steve
1978 kz650b pretty much stock
massachusetts
  • Kawozaki
  • Kawozaki's Avatar
Re: Brake question.
06 Aug 2006 06:34
#67449
The tire needs to be re-mounted to roll in the opposite direction and then the rim can be flipped 180*, putting the rotor on the right. Remove caliper and re-mount on the right side. You really should buy new brake lines, but you can rube goldberg the existing lines.
