Frame Comparison 750/1100
- GPz750KS
05 Aug 2006 07:18
Hey all, I need a bit of help. I'm tryng to get some information on the frame differences between my '82 GPz750 (KZ750R1) and an '82 GPz1100.
The description I have doesn't help.
The 750 frame is described as, "Double Down Tube".
The 1100 is described as, "Double Loop Cradle"
Since I dont have an '82 1100, I need some help comparing them. I found an aftermarket lower chin fairing that fits the 1100. Just wondering if the downtube width, length and construction is comparible to make it close enough to possibly fit.
Thanks, in advance.
Richard Z.
Thanks, in advance.
Richard Z.
- Mcdroid
- Gone Kwackers
Re: Frame Comparison 750/1100
05 Aug 2006 08:26
Richard:
I have both. I have a few errands to run this morning and I can take some measurements for you later today...but I need you to be precise on what and where you need them.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- GPz750KS
05 Aug 2006 10:13
Im not sure exactly where the measurements need to be taken. This what I am looking at on Ebay. Here is the link.
cgi.ebay.com/ebaymotors/Kawasaki-ELR-KZ-...mZ160013381335QQrdZ1
I can build the framework for this. i was just wondering if it would look like an albatros on the bike.
Thanks,
Richard
Thanks,
Richard
- Mcdroid
- Gone Kwackers
05 Aug 2006 11:41
Richard:
The distance across the front of the frame at the level where the motor attaches to the frame (triangular mounts) is approximately 310-15 mm on the 750, it is about 320 mm on the 1100. At the bottom of the frame on the 750 it is about 315-20 mm or so and about 320 mm on the 1100. Suffice to say, the front frame dimensions, although not identical, are very similar. The motor width on the 1100 is greater but the bikes are pretty similar. The fundamental visual difference between the two is the presence of a frame cross member on the 1100 (on the front of the bike between the down tubes, below the exhausts) and none on the 750. Hope this helps.
Free free to ask additional info, if needed.
Post edited by: Mcdroid, at: 2006/08/05 14:42
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- GPz750KS
05 Aug 2006 13:15
Thank you for doing that for me. It seems that this is possible without a huge issue. Thanks Again for measuring for me. Sound like if it will fit aroung the 1100 it will definately fit the 750.
Thanks,
Richard
Thanks,
Richard
- Mcdroid
- Gone Kwackers
05 Aug 2006 13:24
Sure, post pictures...I'd like to see the end result.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
