EX 500 RIMS ON 77 KZ650B ?
- NIGHT RUNNER
02 Aug 2006 09:23
I WAS WONDERING IF THIS RIMS FROM A EX 500 WILL FIT MY KZ 650 , THE HUB LOOKS ALMOST THE SAME , PLEASE HELP! IT WOULD LOOK GREAT.:whistle:
- steell
Re: EX 500 RIMS ON 77 KZ650B ?
02 Aug 2006 09:54
1st, don't use all caps when you post, that's like yelling at someone.
2nd, under the "KZ Information" tab at the top of the page is a "Filebase" link, if you look through the Filebase you will find a list of what bikes use what wheel bearings. If the EX500 and your bike use the same wheel bearings then the axles are the same diameter. If the axles are the same diameter then it's a matter of using spacers to get it lined up, and dealing with the rear (or front) brake.
You need to check hub width for the front also.
Anything will fit if you are determined enough
- NIGHT RUNNER
