Light squeaking from brake pads
  • mind2find
  • mind2find's Avatar Topic Author
29 Jul 2006 20:37
#65790
Ok:
I'm getting an oscillating squeaking sound from my front tire. Goes away with a very little braking. Is there a way to adjust the brake-pad clearance so I can back them off a bit and stop the squeaking? Is there something else I should be concerned about?
I don't want to think about the front disc being warped. :unsure:
1976 KZ-750B1 (late model)
1976 KZ-750B1 (early model) Parts Bike
Boston, MA
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Light squeaking from brake pads
29 Jul 2006 20:54
#65794
You could try applying a skin of silicone behind the pads,if it's a vibration squeek...OR...check out what this Guy did...
www.yankeecruisah.com/brake_squeal.html
Post edited by: Sandy, at: 2006/07/29 23:54
1977 KZ1000 A-1
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
29 Jul 2006 21:34
#65808
Hey mind2find,
Have you bled the brakes lately? What was the condition of the fluid? If the fluid in the caliper gets gummed up it can restrict the natural return effect of the seals and cause the brakes to drag. You may be experiencing the first symptom.
Sometimes, I find that just pumping some new fluid through is enough to get things freed up.
KZCSI
Post edited by: KZCSI, at: 2006/07/30 00:37
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
