Easy....cush drive tightening
- coolbreeze
29 Jul 2006 02:41
Wondering if anyone see's any adverse affects that might stem from placing a peice of bicycle intertube over each one of the cush drive dividers on the sprocket hub to take out the play in the cush drive. You can down or up size the tube depending on the amount of play to be taken out. I did it to my bike a couple months ago & so far so good & it sure is allot less hassel then the winshield epoxie. check out the pic, tried to explain as best I could (which wasn't very good!!LOL). I searched the archives & didn't see where it had been mentioned... Shoot I might of missed the boat & this is common knowlage!!!
Any how hope everyone has a super weekend, go fast & be safe!!! Later
- Biquetoast
- King Jeremy The Wicked
Re: Easy....cush drive tightening
29 Jul 2006 04:21
coolbreeze wrote:
Second, actually, I did some research on this a while back here in the this forum and in the "archive" - there are quite a few threads about it. Some people like building a rubberized "form" or "mold" that augments the existing cush drive, some people like the tube ideal like yours, and then there's the people who just add an epoxy in there...
After reading them all, I was ready to try the innertube method myself, then a NOS cush drive came up on eBay for ~$30...
First, welcome to the forum!Wondering if anyone see's any adverse affects that might stem from placing a peice of bicycle intertube over each one of the cush drive dividers on the sprocket hub to take out the play in the cush drive....
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- OKC_Kent
29 Jul 2006 06:36
I heard about the inner tube fix too, if it works that's all that matters. I fixed mine by removing the cush and applying Auto Goop to the sides. When it dried I popped it back in and that has been working great for over 4000 miles.
Cashion, OK
78 KZ650 B2 85,000+ miles
- Fossil
29 Jul 2006 09:01
The cush drive on my bike is quite a snug fit inside the hub, no play at all. I spray silicone lube on it when assembling to allow it to "squirm " around in there smoothly.
- Whirl
- Sandy
- Fly High,Tony
29 Jul 2006 13:57
I remember this topic from way back...good call...check this out(archives)...
kzrider.com/forum/viewthread.php?tid=10776
1977 KZ1000 A-1
- bill_wilcox100
29 Jul 2006 19:23
I had the same problem. I used sheet aluminum and cut it into spacers that I fit between the hub and the rubber damper. Guess what? It actually worked and I feel no slack when riding at any speed. True, not as cool a solution technically as some of the others but, people, that's what I had late that night in my work shop and that's what I used. Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- bill_wilcox100
29 Jul 2006 19:24
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
- wireman
29 Jul 2006 21:29
anybody got a cheap talon hub they wanna sell?:whistle:
