Old brake disks???
  • KZQ
  • KZQ's Avatar Topic Author
  • Administrator
  • Administrator
Old brake disks???
27 Jul 2006 17:56
#65291
I'd give way too much for a NOS rear brake disk for my 1985 1300. Unfortunately, "Way too much..." doesn't seem to be important, they're aren't any.
Years ago I interviewed for a couple of jobs that involved using some sort of plasma system to spray metal onto worn aircraft parts to allow them to be remachined and reused.
Foward thirty years: Why can't I just weld em up?
Probably because they'd warp unpredictabally.
The real question is hasn't any one figured out a way to resurface brake disks?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • 77KZ650
  • 77KZ650's Avatar
Re: Old brake disks???
27 Jul 2006 18:12
#65294
just an idea, but maybe a cam company could do it? they weld on extra metal then grind to their specs
07 MDP Rookie of the Year
  • craigpuckett
  • craigpuckett's Avatar
27 Jul 2006 18:37
#65307
KZCSI
flywheel grinder/surfacer works. B)
  • KZQ
  • Administrator
  • Administrator
27 Jul 2006 19:30
#65327
I'm looking to add material!
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Pterosaur
  • Pterosaur's Avatar
27 Jul 2006 20:28
#65351
Been awhile since I've done any real technical reading on the process you're referring to - metallizing.
Used to be done to high-buck value industrial machinery - shafts, trunions, high-wear pieces that would be extraordinarily expensive to replace - and as an anti corrosion treatment to items like jet engine compressor stages.
Still can be done, but I think the process has been bypassed technologically by solid-state lubricant bonding with teflon and ceramics.
Mostly done for corrosion control now, it seems...
www.sulzermetco.com/
Anyways, my guess is that between the deposition alloy, the area involved and the machine processes necessary to spec out a disc, it just ain't cost effective - easier and cheaper to get a 12" steel rod blank and machine a new disc.
  • rgpbeme
  • rgpbeme's Avatar
27 Jul 2006 21:00
#65359
could a machine shop redrill the mounting holes on a 1000 or something close in size
