Fork Oil Capacity 76 900 KZ
- thetemples
25 Jul 2006 20:23
I just acquired my first kz and the front forks had no oil in them. I thought those bumps seemed a little harsh. Anyway, I haven't picked up a manual yet and need to put oil back in . I was going to go 10wt racing fork oil in them. What is the cc capacity ? They are completely torn down at the moment. I noticed that these do not have air valves on them like the newer kz's. Will these still produce a decent ride even though they dont run with some compressed air in them? What year did they introduce the air/oil fork?
Thanks
76 kz900
Kentucky
Thanks
76 kz900
Kentucky
- wireman
Re: Fork Oil Capacity 76 900 KZ
25 Jul 2006 20:54
180-188 cc's of oil;) id run a little heavier oil these bikes are pretty heavy .
- ltdrider
26 Jul 2006 06:38
The Kaw Manual for a '76 900 recommends 175 cc of SAE10W oil in each side. You can also check it by measuring the level in the forks with a 'dipstick'.
Measure the oil level from the top of the fork tube. Should be 426mm (16.7 inches).
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- thetemples
26 Jul 2006 07:03
Is that measurement with the tubes collapsed and the springs inside?
Wow - SAE10W - Just like motor oil?? What do you all recommend?
And you all are right, this is a heavy bike. When I rode it with virtually no oil, it sure did feel scary on big bumps.
- ltdrider
26 Jul 2006 07:25
Mesure the oil level with the tubes extended. Put it on the center stand.
SAE10W is NOT motor oil. It's thin. The oil you put in your Bike's crankcase is 40W or 50W. But an auto parts store should have the 10W oil. You'll need about 12 oz for both tubes.
Greensboro, NC
Greensboro, NC
- trippivot
26 Jul 2006 07:54
1976-1977 kz900
5.9 oz dry(174cc)each tube
4.7oz wet (140cc)
oil level measurement in done tubes extended and spring out. 16.8 inches (426mm)
some guys use ATF it is 10 weight oil and anti foaming
I use 20 weight fork oil
now is a good time to measure the spring length
if they are shorter than 17.9 inches or not equal (455mm) time for new progressive springs
4.7oz wet (140cc)
- thetemples
25 Aug 2006 12:25
I got the CD you sent me.. awesome - I am going to post it this weekend and send a link for anyone in the future that might want to download it directly.
