7/8 Offset Sprocket
- Turtle
7/8 Offset Sprocket
25 Jul 2006 13:45
I am currently mounting a 1991 ZR 750 Zephyr swing arm on my 80 MkII. Using a 1992 ZX1100 rear wheel.
I am wondering about mounting a 7/8 offset sprocket, not sure if I need that much but this looks the closest, I will re-measure after I get the tire mounted to the wheel this weekend.
Will I need extra bracing for this offset? Like a bearing support?
Thank You
Thank You
1980 KZ 1000 A4 with 750 Zephyr swing arm and ZX-9 rear wheel
- wireman
Re: 7/8 Offset Sprocket
25 Jul 2006 13:49
yeah youre getting out there quite a ways,gonna make life rough on output shaft and bearings.
- racer54
25 Jul 2006 16:24
I've never heard of a 7/8 offset for a KZ. I belive someone makes one for a GS though, but I could be wrong.As far as I know...5/8 is the big one for a KZ, unless you go to 3" offset.
- 77KZ650
25 Jul 2006 17:09
Are you sure that you need that much offset? Im going to be running a 6 inch zx7 wheel in a zx6 swingarm and i will only need 3/8 offset
07 MDP Rookie of the Year
- Turtle
26 Jul 2006 11:17
I was wrong, and I'm glad.
I got the tire mounted this morning and got everything lined up nicely with spacers, and brake. And it looks like 3/8 is going to do it. I am glad I do not need a bearing support.
www.pmfronline.com/ do make a 7/8 offset for the KZ. I plan on buying from PMFR as they are local and I know John the owner. Hopefully I can get a discount.
Unless there is a cheaper alternative from another bike that works. If so please let me know.
- racer54
26 Jul 2006 16:44
That's great! I'm going to be building another bike this winter and knowing there is a 7/8 offset makes it more feasible. Wasn't sure if 5/8 offset was going to be enough. Glad you started this!
- mark1122
- Keep twisting it
28 Jul 2006 15:18
won't a 7/8" hit the frame?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
