Can't Open My Chain's MasterLink
  • ltdrider
  • ltdrider's Avatar Topic Author
24 Jul 2006 11:55
#64275
Got a new o-ring chain from Jeff@Z1, and I was going to install it last weekend. Big mistake.... way too hot to work on the bike.
Anyway, my old chain has a masterlink that uses a retaining clip... not riveted.
So I remove the clip, but I can't get the little plate under the clip to come off. It's totally frozen to the masterlink. Shouldn't the link just come apart once you remove the retaining clip?
I don't want to cut the old chain... it's stretched some, but still can be used for a spare.
Help!
Post edited by: ltdrider, at: 2006/07/24 14:55
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • mariozappa
  • mariozappa's Avatar
Re: Can't Open My Chain's MasterLink
24 Jul 2006 12:21
#64278
When I put my new chain on, I had to use a small chain press (I think some use vice grips) to get it on. I don't ever think it will come off unless I cut it off.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • wireman
  • wireman's Avatar
24 Jul 2006 14:29
#64321
if you have enough slack in chain soak it with wd40 or something like that ,take a punch or beater screwdriver and a hammer and have at it!:evil:
  • RonKZ650
  • RonKZ650's Avatar
24 Jul 2006 16:11
#64341
The masterlink is a tight press fit, so it won't just fall off once the clip is removed. You need to get a little rough with it. Usually visegrips can get a good enough bite on the pins to press them in to get the plate off.
  • baldtires
  • baldtires's Avatar
24 Jul 2006 16:46
#64347
you need to tap something like a pen knife blade
behind the plate to get it out enough to get a screwdriver behind it
be careful,sorry about your knife
  • hydrolazer
  • hydrolazer's Avatar
24 Jul 2006 19:05
#64403
try this,,,lightly file around the pins and the plate should pop off easier
\'79 kaw 1000 ltd
  • BSKZ650
  • BSKZ650's Avatar
25 Jul 2006 05:32
#64495
when I replace the chain, I will take a grinder and cut one of the links on the bottom of the chain in half, a whole lot faster than fighting with the master link,
77 ltd1000, current rider
76 kz900, just waiting
