which brakes are a direct swap?
- MkII
03 Nov 2005 20:29
Need to know what calipers/rotors,ect from other models are a direct bolt on for my 1977 KZ1000. Please list any possible bikes ex. KZ650, CSR, ect. Also same question for wheels. thank you.
1977A1 current project: 1075, Web cams, VM29's Cavanaugh massaged head, Z1 crank
1979A3A Parked in 1986 left in shed
Phx,Az
Phx,Az
- steell
Re: which brakes are a direct swap?
04 Nov 2005 06:58
Are you looking for an upgrade or just replacements?
Front calipers are interchangeable between 77-80 KZ1000 and 76-80 KZ750 twins, and 77-80 KZ650, as are the rotors. Rear brakes are a different story, can't help you any on that.
Wheels are interchangable between the 77-80 KZ1000 and 76-80 KZ750 twins (front and rear on the 76-79 750 twin, front only on the 80 750 twin due to rear drum brake), and 77-80 KZ650 (front only).
- beaterbike
07 Nov 2005 13:19
steell...translation please..
are the models interchangeable, or the years within the models.. my reason for asking is z1enterprises is not showing thier stainless steel rotors as being super interchangeable.....450, 1000, and 1100 only.
- donthekawguy
07 Nov 2005 14:14
You can use a set of ltd wheels and brakes.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Allshookup
07 Nov 2005 14:18
Is there any bike out there that would be dual piston or some other type of upgrade that is a direct swap or minimal mod?
- luvmykaw
09 Nov 2005 08:04
MkII wrote:
These parts interchange/swap with a 1977 KZ 1000 A1:
Front caliper assembly part # 43041-029:
1977 A1 only
Rotor part # 21007-1004:
KZ 900 B1 76
KZ 900 C2 76
KZ 1000 A2 78
KZ 1000 A2A 78 KZ 1000 B1 78
KZ 1000 B1 77
KZ 1000 B2 78
KZ 1000 C1 78
KZ 1000 C1A 78
KZ 1000 D1 78
Front wheel assembly, part #41074-047:
KH 500 A8 76
KZ 650 B1 77
KZ 650 B2 78
KZ 650 B2A 78
KZ 650 B3 79
KZ 750 B1 76 (TWIN)
KZ 750 B2 77 (TWIN)
KZ 750 B3 78 (TWIN)
KZ 750 B4 79 (TWIN)
KZ 900 A4 76
KZ 900 A5 77
KZ 900 C2 76 (POLICE)
Rear wheel assembly, part #41073-5063
KZ 1000 A1 77 / A2 78 only
This is just cross referencing part numbers. Hopefully somone will give you a tip on different modifications/adaptations.
Post edited by: luvmykaw, at: 2005/11/09 11:06
1977 A1 only
KZ 900 B1 76
KZ 900 C2 76
KZ 1000 A2 78
KZ 1000 B1 77
KZ 1000 B2 78
KZ 1000 C1 78
KZ 1000 C1A 78
KZ 1000 D1 78
KH 500 A8 76
KZ 650 B1 77
KZ 650 B2 78
KZ 650 B2A 78
KZ 650 B3 79
KZ 750 B1 76 (TWIN)
KZ 750 B2 77 (TWIN)
KZ 750 B3 78 (TWIN)
KZ 750 B4 79 (TWIN)
KZ 900 A4 76
KZ 900 A5 77
