Brake pistons
  • 77Davo650
  • 77Davo650's Avatar Topic Author
Brake pistons
19 Jul 2006 06:23
#63118
I am not a brake man so please forgive me if this question is silly.
I got my two front and one rear disc brake calipers off and tore them down to what you see in the pic.
I assume the piston is supposed to slide easily, but it is a real bugger on all of the calipers to get the piston to move at all.
Is the piston supposed to slide right out? I don't want to be yanking on it all evening only to find out it needs some special trick to get that sucker out.
The bike did sit for a while, just FYI. The front calipers don't look near as bad or rusty as this one, and I do have a spare rear caliper.
Thanks.
77 KZ650 C1 (sold)
78 KZ650 B2 (sold)
78 KZ400 B1 (sold)
78 kz400 C1 (resto-mod)
78 kz400 C1 (hardtail low chop)
couple of possible project kz's in parts
  • 77Davo650
Re: Brake pistons
19 Jul 2006 07:24
#63125
Okay nevermind, I looked in the previous posts and found the answer.
My bad. :)
77 KZ650 C1 (sold)
78 KZ650 B2 (sold)
78 KZ400 B1 (sold)
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Brake pistons
19 Jul 2006 08:30
#63138
Dave...I'm assuming that You read that compessed air will assist You in removing the pistons...BE CAREFUL!!
Put a rag in between the edge of the piston,and the opposite side of the caliper(to absorb the impact)...the piston MAY come out quite abruptly!...KEEP YOUR HANDS CLEAR!
Good luck,Bud.B)
1977 KZ1000 A-1
