How much difference between a '81 kz 650 and kz750?
  • fuzzwardo
  • fuzzwardo's Avatar Topic Author
17 Jul 2006 05:37
#62539
Are these somewhat interchangable? I have a motor for a kz650 that isn't being used and a chance to get a kz750 donor with out a motor and was wondering what parts I maybe could use.
Thanks
1978 Kz650B
2001 ZX9R
1996 zx9r project
1985 Suzuki SP250
1991 Harley Electra-glide classic
  • JMKZHI
  • JMKZHI's Avatar
Re: .
17 Jul 2006 06:57 - 03 Dec 2008 18:51
#62560
del
Last edit: 03 Dec 2008 18:51 by JMKZHI.
  • steell
  • steell's Avatar
Re: How much difference between a '81 kz 650 and kz750?
17 Jul 2006 07:55
#62581
If your 81 KZ650 motor did not come with a kickstart, then it is pretty much the same as the 81 KZ750 motor. Same crank, rods, cam chain, intake valves, etc, however the cases are a little different (so are the exhaust valves).
It should not take more than a couple of spacers (you can use washers) to bolt it in.
The KZ750 head, cams, block, and pistons will bolt right on using the 750 (or 650) cam sprockets because the non kickstart 650 motor uses the same HyVo cam chain.
  • fuzzwardo
17 Jul 2006 10:04
#62622
The 650 is a non-kick start model. The way it sounds is that almost everything is able to swap then if the frame is the same. Right.
1978 Kz650B
2001 ZX9R
1996 zx9r project
1985 Suzuki SP250
