RAce Tech Cartridge emulators
  • Dave Sloan
  • Dave Sloan's Avatar Topic Author
16 Jul 2006 20:00
#62486
I know this was asked some time ago but has anyone on this forum fitted Race Tech cartridge emulators to their
Zed, especially the KZ650?
If not has anyone got a set of forks that are dismantled that can get the dimensions that Race tech need to say what will fir?
Info needed is:-
Fork Tube id ___________
Damping Rod Cup id ___________
Damping Rod id (flat top style) __________
Spring id _________
ANy help would be grrat as I realy want to get some but dont want to stip the front end to get the sizes and then wait weeks for them to get shipped to Australia.
Z650B2 - Injected
  • steell
  • steell's Avatar
Re: RAce Tech Cartridge emulators
16 Jul 2006 20:11
#62492
If no one else answers by tomorrow I'll see if I can dig out the 78-79 KZ650SR front end that's stashed in the garage somewhere and get the measurements.
  • Dave Sloan
16 Jul 2006 20:33
#62501
That would be awesome. thanks
Z650B2 - Injected
  • steell
  • steell's Avatar
17 Jul 2006 17:46
#62745
The upper tube is threaded at the top and I don't have any way of measuring the ID below the threads. OD is 36mm in case you need it.
ID of the spring is 15.88mm
OD of the spring is 24.66mm
ID of the dampener rod is 12.33mm at the seal end.
OD of the dampener rod at the seal end is 24.33mm
I don't know what you mean by "flat top style" though.
Hope that helps :)
  • Dave Sloan
17 Jul 2006 19:02
#62752
I Steell, thats just what I need, thanks very much :)
I will email race tech and give them the sizes and they will let me know which one to use.
The flat top style is what come of the older bikes use where the damping tube protrudes through a the top seal bush, all the jap bikes have the cupped one.
Can you please tell me what teh site is that has all the part numbers etc on it per model?
I though it was buy kawasaki but didnt find it, I just want to confirm that hte SR and the B2 have the same forks although Im 90%sure tehy do.
Thanks again
Cheers
Z650B2 - Injected
  • steell
  • steell's Avatar
17 Jul 2006 19:09
#62753
www.buykawasaki.com/Default.asp ?
Click on "Order Service and Owners Manuals for your Kawasaki More info", then click on the top "Continue" button and the rest is fairly obvious.
Post edited by: steell, at: 2006/07/18 23:40
  • Dave Sloan
18 Jul 2006 18:39
#62987
steell, this is the link to the Race tech site on the sizing for the Cartridge emulators if you wnat to see how the fitment works
www.racetech.com/articles/EmulatorFitting.htm
Z650B2 - Injected
  • Dave Sloan
19 Jul 2006 02:12
#63098
Steell, could you please recheck the id of the dampner rod, if you could have a look at the emulator at the link that i've attached in the previous email and comfirm that the ID of the dampner rod as 12.33 seems small
Thanks
Cheers
Z650B2 - Injected
  • steell
  • steell's Avatar
19 Jul 2006 17:20
#63226
I had a look and it seems to me that it is a "Flat top" and they want the tube ID, and that's the figure I posted. There is no "cup" on top of the rod, it's flat and has a split washer like seal that fits in a groove.
I wasn't sure the image would post, but it did :)
That's pretty much what it looks like, a hair less than 1/2" ID.
Post edited by: steell, at: 2006/07/19 20:22
  • Dave Sloan
19 Jul 2006 17:34
#63230
Thanks Steve.
Cheers'
Z650B2 - Injected
