Pear nuts
  • Daveuk
  • Daveuk's Avatar Topic Author
Pear nuts
14 Nov 2026 00:59
#929096
Just about to lay my z1000motor on its side to pop the frame over it. I have bought some smart pmc engine mounts to fit.
​​​​​​​ I guess the strange pear nuts fit at the bottom mounts but how, any help much appreciated.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Pear nuts
14 Nov 2026 01:39
#929097
Are these the ones that secure the bottom mounts? If so make sure you have the right bolts - I believe these are the that damage the casing if too long
The following user(s) said Thank You: slmjim+Z1BEBE
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: Pear nuts
14 Nov 2026 04:35
#929100
   That's an important point.  We've seen chatter here on KZR about exactly that happening.
   When all threads are engaged in the teardrop nut, there's very little clearance between the end of the bolt and the motor case.  Don't count on more than ~3mm clearance max.  If the bolt is too long it will force its way into the case & crack / puncture it.
   Since you're installing with the motor & frame on their sides, it will be easy to observe clearance between the end of end of the bolt and the cavity the teardrop nut is in as the bolt is  being tightened.  Otherwise, when the bike is upright, a mirror or borescope is needed to observe that cavity.  Make sure the thick split lock washer is in place under the bolt head.  If more bolt threaded end clearance is needed, flat washers may be used under the lock washer as shims.  A 0.5mm feeler gauge is our go-to measurement for bolt end clearance in the cavity when the bolt is tight.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
The following user(s) said Thank You: Mcdroid, asphalt900, Wookie58
  • asphalt900
  • asphalt900's Avatar
Re: Pear nuts
14 Nov 2026 05:52
#929104
As Ole Slim Jim pointed out, Please don't position these 12MM bolts in the wrong positions, You'll punch right thru the lower engine case!! There are Two sized length, 71 and 56mm. Being a 1977, should have a raised font of 4. First institute of using numerals on bolts, see picture. I've never bought nor needed PMC replacements but "if" those have different looking sides on the "pear", face flat machined side towards outside upon assembly. Like the other hardware on these it called a Type 1, chamfered on one side/flat on the other. The 56mm length goes on the Right when sitting on bike and goes thru the triangle loose plate.
  • slmjim+Z1BEBE
Re: Pear nuts
15 Nov 2026 06:16
#929124
   We should add that we find longer bolts are desirable when case guards are installed for sufficient thread engagement in the teardrop nut.  The lower mount of case guards is about half as thick as the teardrop nuts, resulting in shallow / insufficient thread engagement.  We've sourced bolts from Fastenal for this.  This is also where we've used flat washers as shims under the split lock washer for bolt end clearance.
   Getting the bolts started when the motor is installed & bike is upright can be eased by folding a narrow strip of cardboard box in half or thirds and sliding it between the nut & case to jam the nut firmly in place square against the surface of the cavity, aligned with the hole.  Remove the cardboard once the bolt is started a couple threads to monitor bolt end clearance.
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
  • Cra-z1
  • Cra-z1's Avatar
Re: Pear nuts
15 Nov 2026 09:59 - 15 Nov 2026 10:00
#929132
This is what will happen if you use the wrong bolt. This is from an engine that someone did this to. Not me. Could happen to the other side I guess but this side is closer.
Last edit: 15 Nov 2026 10:00 by Cra-z1.
The following user(s) said Thank You: Mcdroid, slmjim+Z1BEBE, !Seymore, Daveuk
  • Daveuk
Re: Pear nuts
18 Nov 2026 12:44
#929191
I had no idea these were so critical, will
measure the hole depth and check clearance.
​​​​​​​Thanks for all response.
