Fairing vibrations
  • Lpar
  • Lpar's Avatar Topic Author
Fairing vibrations
18 Oct 2026 19:30
#928600
My 95 kz1000p has a really annoying buzzing noise and vibration at certain speeds and RPMs, i have checked all the rubber mounts and made sure everything's snugged up and I don't have anything loose. I'm pretty sure it's my headlight rattling around and vibrating in the fairing. Is this just how the old cop bikes are? Or is there a fix for it.
  • rickysnicker
  • rickysnicker's Avatar
Re: Fairing vibrations
19 Oct 2026 06:21
#928605
Is there any loose wiring inside the fairing?  If so, you could tape or zip tie the wires together.  I noticed the trim ring on my P rattles a bit.  There is only one screw holding it on.  I may put some small pieces of foam on the inside of the trim ring.
  • Lpar
19 Oct 2026 09:57
#928609
Yeah when I got the bike, I pulled probably ten miles of extra wiring and random switches and accessories out of the cowling. I noticed the headlight ring as well, i'm probably going to try and use some rubber or foam behind it to try and insulate it and absorb some vibrations.
The following user(s) said Thank You: rickysnicker
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
25 Oct 2026 05:42
#928679
Mine had that annoying rattle/vibration as well. I never did figure that out and assumed they were all like that.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
