Possible adaptation of gas tank.
  • RippyTheRazor
  • RippyTheRazor's Avatar Topic Author
25 Aug 2026 21:33
#927019
Looking into replacing my 1983 KZ750K gas tank. Which seems to be non-existent. Could someone possibly send me a couple pictures with their gas tank removed so I could possibly think about welding up a solution to use another gas tank?
Thanks!
  • H1Vindicator
  • H1Vindicator's Avatar
Re: Possible adaptation of gas tank.
28 Aug 2026 07:19 - 29 Aug 2026 06:01
#927071
tanks. the 82-84 750 twin fuel tanks are probably interchangeable. all mount the same w a tab that fits into a frame damper. the 82 model is an m1 CSR. there are several tanks on ebaay w the tab but no real good pics of it. for an alternate tank to modify: maybe a 750-4 ltd or 650-csr. similar size/shape tanks as your Ltd-Belt. I have no idea if the front mounts would fit the same. and those have an extra opening for a fuel switch.
ebaay 750csr >> 800426705902, 147016656787, & 158216987475<>tab cut off ???
ebaay 750ltd >> 234899959749 & 326330569647
Last edit: 29 Aug 2026 06:01 by H1Vindicator.
