83 GPZ 750 chain conversion
  • notgoodwithnames
  • notgoodwithnames's Avatar Topic Author
22 Aug 2026 20:42
#926938
Tackling a final problem while I wait for my fork rebuild to get here, chain conversion with this nonsensical offset front sprocket. I'd really like to get a 520 if possible, will do a 530 if that's easier, but after taking off the old rusty 630 chain I really don't want to put that back on. Unfortunately my bike is not currently in a position for me to mock up new sprockets so I'm curious how others have done it. I've seen some people say you can use spacers behind a flat sprocket and make it work, I've seen some posts from 10-15 years ago about people making custom offset ones. Any insight would be appreciated
1983 GPZ 750
  • zed1015
  • zed1015's Avatar
Re: 83 GPZ 750 chain conversion
23 Aug 2026 00:59 - 23 Aug 2026 04:11
#926939
Why do you need an offset sprocket ???
Like for like 630 and 530 chains are the same width.
It's the pitch that is different.
If the stock sprocket has an offset then get hold of a JT sprockets catalogue which lists measurements, fitments and offsets for most bikes which may have a 530 alternative to what you have, possibly from a ZR750 or similar.
Failing that a simple spacer behind a flat sprocket will do the job depending on the offset needed and whether the output shaft is long enough.
Last edit: 23 Aug 2026 04:11 by zed1015.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
23 Aug 2026 06:00
#926941
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • notgoodwithnames
23 Aug 2026 08:54
#926942
Because the 83-85 GPZ 750 has an offset front sprocket
1983 GPZ 750
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
23 Aug 2026 11:05
#926943
Then any replacement sprocket if supplied for the right bike should meet factory off set specs
  • notgoodwithnames
23 Aug 2026 11:23
#926944
I'm aware of how a chain conversion works. I'm looking to see if anybody still makes the correct sprockets or what bike they can be sourced from because JT only makes a 630
1983 GPZ 750
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
23 Aug 2026 12:24
#926945
Not sure where in the world you are ? there are kits listed to convert to 530 but these mainly seem to be from European suppliers so if you are in the US shipping and tariffs will make it expensive
  • zed1015
  • zed1015's Avatar
23 Aug 2026 14:01 - 23 Aug 2026 14:02
#926950
I've just been through my own JT catalogue and there's nothing remotely close to the GPZs JTF514 front sprocket in either 520 or 530 pitch with the correct offset and Z13 spline so unless someone else out there is making a specific conversion kit you will have to either have a custom sprocket made, make your own or stick with the stock 630..
Last edit: 23 Aug 2026 14:02 by zed1015.
  • StreetfighterKz
  • StreetfighterKz's Avatar
23 Aug 2026 17:30
#926954
I sourced a couple of sprockets from PBI (RIP 2022). So you may be able to find some on eBay sporadically.  As a matter of fact, I have a 1/4” offset 17T 530 front sprocket of their’s on my Gpz750 project right now.   I also found a 520 front sprocket from Sunstar on Webike Japan.   It’s offset and meant fora Suzuki Gs but I needed it for the Ducati GT1000 wheels on my Kz1000 build. It wasn’t terribly expensive but I ordered before Trump’s second term so your result may vary.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • notgoodwithnames
24 Aug 2026 07:33
#926962
Could you link these because I can't find any
1983 GPZ 750
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
24 Aug 2026 08:04
#926964
If your bike is a "uni-trak" this seems to be the only one that might do it (there are a couple of other suppliers for the twin shock R1 GPZ)
Transmission kit DID Professional chain 530 sprocket Kawasaki
  • notgoodwithnames
24 Aug 2026 08:59
#926968
This is for a 750 turbo which does not have an offset sprocket
1983 GPZ 750
