Fuel in gas tank boiling. Does heat shield tape work?
  • ckahleer
  • ckahleer's Avatar Topic Author
08 Aug 2026 11:24
#926572
I'm looking to eliminate or at least reduce the boiling fuel in the gas tank of my ZL600. After riding the bike, it has a strong boil for several minutes when parked. The fan stays on for about 10 seconds after shutting off the bike.
Some options I'm considering are:
Putting heat shield tape on under side of gas tank.
Installing a lower tempeture thermostat and fan switch.
Do nothing and let it boil.
97 ZL600
94 VF750c
94 KE100
82 KZ305
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
Re: Fuel in gas tank boiling. Does heat shield tape work?
08 Aug 2026 11:41
#926573
So, when was the last time you checked the fluid level or the water/AF? When was the last time you CHANGED the AF? Might be time?
Oh, how do you KNOW the fuel is "boiling"?
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
  • ckahleer
09 Aug 2026 06:36
#926587
Once you shut off the engine and the fan stops, you can hear it boiling. When you open the gas cap you can see it boiling.
97 ZL600
94 VF750c
94 KE100
82 KZ305
  • Injected
  • Injected's Avatar
09 Aug 2026 06:55
#926590
Check to see if the gas cap is venting. Spiders can get into the vent hole and block the gas fumes from escaping.
Sounds like BS but I have seen that happen.
1978 KZ650B2 modified project
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
12 Aug 2026 22:52 - 12 Aug 2026 22:54
#926687
I use the heat tape on my supermoto.  High ethanol gas boils easier, I have a problem with heat soak/fuel boiling on my lawn tractor.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 12 Aug 2026 22:54 by Kidkawie.
