Fork spring choices
  • notgoodwithnames
  • notgoodwithnames's Avatar Topic Author
Fork spring choices
26 Jul 2026 13:10
#926118
Got a 1983 GPZ750 stripped down in my living room currently, have most everything sorted to be put back together hopefully by October, critical piece I'm missing though is a new set of fork springs. So far all I've found for new options is a company out of Germany. I'd prefer to get a stiffer straight rate spring as I'm modernizing by eliminating the air system but it's looking like I might not have many options
Curious about what other GPZ owners here did with theirs
1983 GPZ 750
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Fork spring choices
26 Jul 2026 13:14 - 26 Jul 2026 14:49
#926119
Check the fsm for the overall uncompressed length and measure yours. Chances are they are fine. 70s forks were always fairly soft. Easily remedied by adding preliad above the spring. Half an inch is normally sufficient.
Last edit: 26 Jul 2026 14:49 by Warren3200gt.
  • Nessism
  • Nessism's Avatar
26 Jul 2026 14:06
#926122
I got Sonic Springs for my 750.  They offer a few different rates, based on your weight and riding type.  They come with a hunk of PVC pipe for making spacers, so the basic length of the springs is unimportant.  And with many bikes of the KZ era, the springs were soft, and air caps were used at the top as a spring supplement.  Using air increases fork stiction, though, and the effect changes with temperature.  Since switching to Sonic, I don't use any air at all.
  • notgoodwithnames
26 Jul 2026 16:53
#926130
I have no doubt the current springs are likely fine as the bike only covered 14k before being garaged and neglected for seemingly 40 years (original model rear tire is still on it), I am eliminating the air though and would like to put in stronger springs while I have them open anyways
I looked at sonic but they only offer KZ forks and not GPZ, which to my understanding are different diameters
1983 GPZ 750
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
  • notgoodwithnames
27 Jul 2026 09:43
#926166
Where in the world are you ?
Florida
1983 GPZ 750
  • Nessism
  • Nessism's Avatar
27 Jul 2026 18:50
#926180
You could always try measuring the OD and length, then message or call Sonic.  Racetech is another possibility.
  • chopper1963
  • chopper1963's Avatar
  • notgoodwithnames
  • notgoodwithnames
16 Aug 2026 14:54
#926814
Bumping this in case there's something else out there
1983 GPZ 750
  • TexasKZ
  • TexasKZ's Avatar
16 Aug 2026 14:59
#926815
So what do you not like about Progressive, Race Tech and Sonic?
The following user(s) said Thank You: StreetfighterKz
  • StreetfighterKz
  • StreetfighterKz's Avatar
16 Aug 2026 15:59 - 16 Aug 2026 16:00
#926818
Check with Wilbers, Maxon, etc. I checked Hyper-Pro and their springs are progressively wound.
To be honest, unless you’re riding 10/10ths,  you’ll probably never realize the progression of the spring rate.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 16 Aug 2026 16:00 by StreetfighterKz.
