LTD seat conversion
- Len1026
LTD seat conversion
08 Jun 2026 14:04 - 08 Jun 2026 14:05
The seat on my 1982 LTD750 (stepped seat) is not very comfortable. Is there a flat seat on another KZ that will fit my LTD ? Or, will a reproduction KZ 900 or 1000 seat cover fit my seat pan so I just need to shape the foam to fit? Any other options to convert to better flat style seat?
1982 KZ750 LTD
1981 CB900F
1981 CB900F
Last edit: 08 Jun 2026 14:05 by Len1026.
Re: LTD seat conversion
08 Jun 2026 21:00 - 09 Jun 2026 16:13
If you live near a large city, there is likely a motorcycle seat specialist there who could use your seat pan and add customized foam and upholstery. The local custom bike crowd should know.
Companies like Corbin may also take on custom work. Would certainly be worth the price of a call to find out.
If you are adventurous, you can get some better foam at a furniture upholstery shop, shape it yourself and have somebody make a new cover to fit.
Last edit: 09 Jun 2026 16:13 by TexasKZ.
- StreetfighterKz
08 Jun 2026 21:47
Do you have a Kz750H (4-cyl) or a Kz750G (2-cyl)?
The H has a 2-part seat but the G has a single seat pan.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
09 Jun 2026 01:11
The following user(s) said Thank You: Len1026
- Len1026
09 Jun 2026 03:55
I have the 4 cyl h3 version. I emailed mean city cycles Their price starts at $435 and up for a custom seat cover. That's more than I want to spend on a seat. I am considering Texavina.com. They offer seats made in Vietnam for $278 shipped but I'm not sure of the quality. Has anyone bought one of their seats?
1982 KZ750 LTD
1981 CB900F
1981 CB900F
- Nerdy
09 Jun 2026 06:32
I was looking into alternative seats for a 440LTD. If I understand the situation correctly, Texavina and daytrader are more or less the same entity, and you'll get hosed on tariffs trying to ship the seat from Vietnam.
I stripped all of the foam off an OEM seat pan and made a new foam layer from a 2.25"-thick piece from an exercise/balance mat, then made a not-great cover for it with a roll of marine-grade vinyl upholstery. The stamped-out metal points around the bottom edge of the pan wouldn't get through the vinyl, so I had to make starter holes with a utility knife. I do have the appropriate needles and thread to do the corners properly but likely don't have the skill.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- H1Vindicator
09 Jun 2026 06:42 - 09 Jun 2026 07:08
there might be a seat cover listed on ebaayy. the 1-piece 750H seat should be the same as the 650csr. there's a custom made csr seat cover listed on eb w stretchy material that's probably similar to the material on a travelcade seat cover from back in the day.
650csr seat cover >> eb item number: 224034705437
Last edit: 09 Jun 2026 07:08 by H1Vindicator.
- Len1026
09 Jun 2026 13:12
Does anyone have a seat from Texavina? How do you like it?
1982 KZ750 LTD
1981 CB900F
1981 CB900F
- Len1026
11 Jun 2026 10:22
I just ordered one from daytrader-07. Hope it doesn't take too long from Vietnam to Pennsylvania. Thanks for suggestions and comments.
1982 KZ750 LTD
1981 CB900F
1981 CB900F
- quantity
11 Jun 2026 14:51
I went through the same thing with my LTD and looked for different options. The stepped seat limits rider position and IMO looks too bulky. If you want to swap to a flat seat pan you'll need that section of frame from a donor to weld onto yours. Either that or have a custom seat made. The Texavina seats look good, I'd like to see the one you ordered when you install it.
74 KZ400 - 446cc
The following user(s) said Thank You: StreetfighterKz
- Rideallyear
13 Jun 2026 07:50
I had a seat made by Texavina. The price was good but it took a long time to get to the US. Tariffs were not too crazy… not sure how.
The seat pan they give you is so-so. It is a thin metal formed by hand. So even though it was supposed to be a direct fit, I had to fabricate new mounting brackets. Not a deal breaker for me.
The material and stitching was superb however. On par with custom seats I had from the US and Europe, but for half the cost.
Their support is good. The guy wanted to redo my seat because of the misfit. Instead I asked him for extra material to make matching handle. He shipped it at no cost.
So overall, it’s a pretty decent deal for the cost.
80 KZ650 LTD (Project)
81 Honda CX500 (Resto-mod)
20 KLX 140L
21 BMW F850GS
20 KLX 140L
21 BMW F850GS
- Rideallyear
13 Jun 2026 07:53
If you go with Texavina, you could also take their foam and seat cover and fasten it on your orignal seat pan. As long as you taken their original replacement option.
just an idea.
just an idea.
20 KLX 140L
21 BMW F850GS
20 KLX 140L
21 BMW F850GS
