engine number v chassis number
  • sKZballs
  • sKZballs's Avatar Topic Author
18 May 2026 12:47
#924044
Hello, I'm not sure where this one should go but here it is. I have an 83 KZ550 ltd. shaft drive. The vin is JKAKZFM10DA001972 and the engine number is KZ550FE003793. I am under the impression this is the M-1 model but I believe the engine number tells me this is the F-1. What am I doing wrong and what is the verdict?
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: engine number v chassis number
18 May 2026 18:48
#924053
I'm not familiar with the 550 models, but if they're anything like the others, engines are shared between the different models with the same engine capacity.
Have you, or someone else here, have a list of the 550 engine placements?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • TexasKZ
  • TexasKZ's Avatar
18 May 2026 20:56
#924055
The FE engines were used in both the M and F models.
www.kzrider.com/filebase-alias?task=down...id=1178&catid=64&m=0
  • sKZballs
19 May 2026 05:26
#924064
Ok, that makes sense. Thank you! I knew someone would have the answer.
