KZ900 LTD rear tire pressure for OEM MT90-16T?
- slmjim+Z1BEBE
16 Apr 2026 04:56
The tire pressure as published by Mama Kaw that appears on the KZ900 LTD under seat tag and / or in the KZ900 LTD Owners Manual? Surprisingly difficult to find that exact Mama Kaw spec. Not interested in interwebs search responses, as they're generic & all over the place.
TIA
Good Ridin'
slmjim & Z1BEBE
TIA
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- asphalt900
Re: KZ900 LTD rear tire pressure for OEM MT90-16T?
16 Apr 2026 05:39
The original Bridgestone's, do you have an LTD900?
- slmjim+Z1BEBE
16 Apr 2026 06:04 - 16 Apr 2026 06:11No. Only looking for Mama Kaw's published specs.The original Bridgestone's, do you have an LTD900?
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 16 Apr 2026 06:11 by slmjim+Z1BEBE.
- sf4t7
16 Apr 2026 08:28
From the Kawasaki service manual KZ900 LTD supplement, table on page 18:
Front tire ML90-19 26 PSI
Rear tire MT90-16T 1 Rider 22 PSI, 2 Riders 24 PSI
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: slmjim+Z1BEBE, Nessism, asphalt900
- slmjim+Z1BEBE
16 Apr 2026 19:30
Thank You sf4t7. Exactly what we were looking for.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
