1978 KZ1000 LTD B2 - Location of Rear Axle Washer in Relation to Chain Adjuster
  • BlueKZ_3
  • BlueKZ_3's Avatar Topic Author
08 Mar 2026 18:21
#922046
I took the rear wheel off my 1978 LTD to work on the brake caliper. I noticed whoever put the wheel on last placed the 20mm washer (part #92022-248) between the collar (#42032-071) and the chain adjuster (#33044-001), as shown in this picture:
It felt impossible to get the wheel back on in this configuration, like there wasn't enough space between the swing arm's forks. So I wondered if the washer is actually supposed to go between the castle nut and the chain adjuster like so:
None of the service and parts diagrams I looked at showed the relationship between the 20mm washer and the chain adjuster, so I was hoping one of you guys would know. Thanks!
  • zed1015
  • zed1015's Avatar
Re: 1978 KZ1000 LTD B2 - Location of Rear Axle Washer in Relation to Chain Adjuster
09 Mar 2026 01:20
#922051
It felt impossible to get the wheel back on in this configuration, like there wasn't enough space between the swing arm's forks. So I wondered if the washer is actually supposed to go between the castle nut and the chain adjuster.
Thanks!
Yes! the washer is for the nut.
The PO assembled it incorrectly.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
09 Mar 2026 04:07
#922055
That is the same conclusion I came to...that small spacer/thick washer has to go between the nut and chain adjuster. All the literature I went through was fairly vague on the thick washers position.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • 1kz4me
  • 1kz4me's Avatar
11 Mar 2026 18:11
#922141
That’s how I have mine set up washer behind nut.
