Drivechain Sprocket choices???
- peachc
15 Jul 2006 19:28
I am interested in changing my stock setup on my 750 to bring the RPM's down lower on highway travel, but am uncertain on what sprocket selection is good. Can I get away with changing the rear only? or do I need to do front and rear? or am I seeking something that won't really make that much of a difference? Any help would be great!
- Biquetoast
- King Jeremy The Wicked
Re: Drivechain Sprocket choices???
15 Jul 2006 19:35
peachc wrote:
Do you have the 16 front, 106 link sprocket, and 38 rear?
Get a 17 front if you don't have it. Mandatory.
That's a twin, right?I am interested in changing my stock setup on my 750 to bring the RPM's down lower on highway travel, but am uncertain on what sprocket selection is good. Can I get away with changing the rear only? or do I need to do front and rear? or am I seeking something that won't really make that much of a difference? Any help would be great!
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- peachc
15 Jul 2006 19:42
Biquetoast wrote:
Its the 4, I would have to look up the stock setup, the 17 front would make a big difference?
peachc wrote:That's a twin, right?I am interested in changing my stock setup on my 750 to bring the RPM's down lower on highway travel, but am uncertain on what sprocket selection is good. Can I get away with changing the rear only? or do I need to do front and rear? or am I seeking something that won't really make that much of a difference? Any help would be great!
- Biquetoast
15 Jul 2006 20:09
peachc wrote:
Ah! Ignore everthing I said! I have no idea about the 4!!! Ah!! :ohmy: :whistle: :laugh:Its the 4, I would have to look up the stock setup, the 17 front would make a big difference?
kz750twins.com
kz750twins.com
- Vter Bob
15 Jul 2006 20:38
My 550 had a 15 tooth front and a 38 tooth rear. Both were in real good shape with only about 1500 miles on them. Stock gearing on the 550 is 16/38. I replaced the 15 tooth with a 16 and at 55 mph it cut RPM's by about 400 - 500. The trade off is that the bike does not accelerate as fast but that's hardly noticable to me. Top end speed seems a little better but I find the lower RPM's at cruising speed a great improvement. Enough of an improvement to make me think seriously about trying a 17 tooth front sprocket. It shouldn't be any problem to change just one sprocket as long as your chain and the sprocket you are NOT changing are in very good shape.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
- steell
15 Jul 2006 22:37
You probably have a 13 front and a 32 rear, (that's what buykawasaki.com says) and it's 630 chain, you might be able to put a 14 tooth front sprocket on it, but I have ny doubts. Z1 Enterprises lists 13, 14, 15, and 16 tooth sprockets that are claimed to fit your bike, but I'd have to see one mounted on a KZ750H to believe anything larger than a 13 will fit, I tried a 15 tooth 530 sprocket on a 80 KZ750 motor, and it would have taken major modifications to make it fit. As in cut off the shifter shaft.
And Z1 does not list anything smaller than a 32 rear, so I think your best (and maybe only reasonable) option is to convert to 530 chain and sprockets, lot's more gearing options that way, and it bolts on.
- ndali
22 Jul 2006 19:32
For those of you who want to calculate what sprocket combinations will give you in terms of speeds and rpms then throw the following formula into excel. Keep in mind no driveline energy loss is taken into account.
Rear wheel radius (inches)= R
Wheel speed (rpm) = Ws = Es/Pr/Fr/Gr
Engine speed (rpm) = Es
Primary drive ratio = Pr
Final ratio = Fr = Wheel sprocket / Engine sprocket
Gear ratio = Gr
Vehicle speed (mph)= Vs = R*Ws*pi*2*60/12/5280
An example with the numbers off of my bike, 82 kz 750 twin. 16 front, 38 rear are as follows
Rear wheel radius (inches)= R=13
Engine speed (rpm) = Es = 5000
Primary drive ratio = Pr = 57/23=2.47
Final ratio = Fr = Wheel sprocket / Engine sprocket = 16/38 = 2.375
Gear ratio = Gr = 5th gear = 21/24 = .875
Vehicle speed (mph)= Vs = R*Ws*pi*2*60/12/5280 = 69 mph
Gear ratio = Gr
- ndali
22 Jul 2006 19:42
correction
vehicle speed = 75 mph
error updating excel spreadsheet
