Chain tension adjustment on '82 kz440
  • KZfreely
  • KZfreely's Avatar Topic Author
07 Oct 2025 11:20
#917931
Hey guys I have a 1982 KZ440 that has been converted to chain drive from belt drive by the previous owner. I'm curious as the new KZ owner how to adjust chain, and what regular chain tension should be. Thanks!
  • 82KZ305Belt
  • 82KZ305Belt's Avatar
Re: Chain tension adjustment on '82 kz440
07 Oct 2025 15:31 - 07 Oct 2025 15:31
#917951
They made chain models too so I would go with what the Factory Service Manual says for those, which is probably 25-30mm slack. The manual may be on this website somewhere, if not it is here www.kz400.com/Workshop%20manual%20bilder...Service%20Manual.pdf
It should give complete directions.
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
Last edit: 07 Oct 2025 15:31 by 82KZ305Belt.
The following user(s) said Thank You: KZfreely
  • TexasKZ
  • TexasKZ's Avatar
07 Oct 2025 21:18
#917956
  • 82KZ305Belt
08 Oct 2025 06:49
#917972
Also, I think I mentioned this before but make sure its not hitting the frame somewhere because that has been known to happen on some 440 chain conversions.
81 KZ650 CSR
82 KZ305 CSR
  • H1Vindicator
  • H1Vindicator's Avatar
10 Oct 2025 08:13
#918009
motorcycle on center stand. spin the rear wheel by hand while checking the midpoint of the chain to find the tightest spot. there should be about 1" (25mm-30mm) of slack in the chain. ie, 1" of up and down movement. I pull down on the chain, note that point on the ruler, then push up on the chain. 1" is at the midpoint of the spec for my motorcycle. on yours, you'd probably want 1" to 1-1/8".   I use a folding carpenter's ruler taped to a wood block.
  • TexasKZ
  • TexasKZ's Avatar
10 Oct 2025 11:02
#918011
FSM sez 30mm slack on center stand, 25 mm slack on side stand.
www.kzrider.com/filebase-alias?task=down...&id=378&catid=12&m=0
  • H1Vindicator
10 Oct 2025 14:05
#918014
the 80-82 kz440 fsm (part # 99924-1011-03) from the kz400.com site says 25-30mm center stand measurement (440A/C models). 20-25mm side stand measurement (440B models).
