replacing right hand controls
- 82KZ305Belt
29 Sep 2025 06:15
OK I'm sure I'll feel stupid when I find out but I'm stumped. I need to replace my on/off/start switch and if they are in there, I can't find instructions for disassembly in the FSM. Easy enough to detach the wiring at the switch, but how do you remove the throttle cables to move the grip to the new switch housing?
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
82 KZ305 CSR
Re: replacing right hand controls
29 Sep 2025 06:24
There are two screws, accessed on the bottom of the switch housing. Completely remove the two screws, separate the two halves of the housing, the throttle assembly will be released.
Be sure to lubricate the cables while you have it apart.
29 Sep 2025 06:54Stupid is when you "don't" ask and then break somethingOK I'm sure I'll feel stupid when I find out but I'm stumped. I need to replace my on/off/start switch and if they are in there, I can't find instructions for disassembly in the FSM. Easy enough to detach the wiring at the switch, but how do you remove the throttle cables to move the grip to the new switch housing?
- MFP-Joe
29 Sep 2025 08:28
...and if you want to change the (lower) housing to another new one, sure you have to disconnect the throttle cables from the carbs, then you can srew them out of the lower housing.!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Z1000 A2 1977
Greetings, Joe
- 82KZ305Belt
29 Sep 2025 11:39There are two screws, accessed on the bottom of the switch housing. Completely remove the two screws, separate the two halves of the housing, the throttle assembly will be released.
Well the screw part was easy...but the throttle stuff doesn't just pop out.
That's why I asked, because something was gonna break...Wookie58 post=917737 userid=60568Stupid is when you "don't" ask and then break something
This here is what I was actually wondering about, and where something was gonna break, because it doesn't seem to be as simple as it sounds. How do you get the ball end out to remove the cable? I would be surprised if this isn't in the FSM somewhere but I couldn't find it.MFP-Joe post=917739 userid=24810...and if you want to change the (lower) housing to another new one, sure you have to disconnect the throttle cables from the carbs, then you can srew them out of the lower housing.!
I do my best thinking while driving, and while driving home from my morning shift I realized it doesn't matter, since all I really need is to replace the start button, and I can do that without removing the cables. But I'm sure it would be handy to know anyway.
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
- sf4t7
29 Sep 2025 14:54 - 29 Sep 2025 14:54
Disconnect the cables at the carbs and you'll have slack at the handgrip ends to line the cables up with the slots in the throttle grip to remove the cables.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 29 Sep 2025 14:54 by sf4t7.
- KzEnormous
29 Sep 2025 15:29
I've had to fix the start button on my bike twice I believe. I'm not sure if I ever tried to find a new one with any success, but they can be repaired. In my case there is a small bit if circuit board that has the start button on it, the board broke down the middle, breaking the trace. Epoxy and a jumper wire worked well. (The 2nd time) Good luck !
1980 Kz 1000 Ltd -
Currently in resurrection
1980 Kz 440 Ltd -
Waiting for attention, possible sale or part out.
1982 Kz 1000 -
Part donater, sale or scrap metal
1980 Kz 440 Ltd -
1982 Kz 1000 -
- 82KZ305Belt
29 Sep 2025 20:05I've had to fix the start button on my bike twice I believe. I'm not sure if I ever tried to find a new one with any success, but they can be repaired. In my case there is a small bit if circuit board that has the start button on it, the board broke down the middle, breaking the trace. Epoxy and a jumper wire worked well. (The 2nd time) Good luck !
Yeah it was starting to dawn on me that I would have to disconnect them at the carbs, and I was not in favor of doing that. Fortunately just changing the button switch out occurred to me so that's what I did and all is well now. I haven't looked closely at the bad one to see what all went bad with it, but I probably should see if it can be rehabbed. I think the button just fell off, but it was also blowing fuses when I used a bolt to start it.
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
