97 ZL600 speedometer reading 10% high
- ckahleer
26 Sep 2025 11:08
10% makes it easy to do the math while riding, but would still like a more accurate speedometer. my ZL600 has an 18" front wheel. From E-bay images it looks like a speedo drive from a 600 Ninja, that has a 16" front wheel, would fit.
So would the Ninja drive be geared differently, or are they all geared the same regardless of wheel size.
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
Re: 97 ZL600 speedometer reading 10% high
26 Sep 2025 11:35
They aren't all the same, check out stereordinary's recent post for the calculations
The following user(s) said Thank You: TexasKZ
- Stereordinary
27 Sep 2025 07:39 - 27 Sep 2025 07:41
Here’s the thread (starting at the third post):
www.kzrider.com/forum/5-chassis/621661-p...nd-conversion#912953
A breeze from the west.
Last edit: 27 Sep 2025 07:41 by Stereordinary.
- ckahleer
27 Sep 2025 13:26So it looks like I would need a speedometer drive with a 22 or 21 tooth gear. Probbally not going to happen unless there are Kawasaki motorcycles with front 14" wheels.Here’s the thread (starting at the third post):
I don't think reducing the reading buy 4% will be enough. Just makes the math harder.
AI Overview
Motorcycle speedometers are required to show a speed that is never less than the actual speed but can be higher. Because of this, most manufacturers design them to read about 7% to 10% higher than the true speed to ensure they comply with regulations. This is a common requirement in many regions, though specific rules may vary by location.
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
27 Sep 2025 17:07
All vehicles read “high” not only to meet regulations but also to avoid litigation claims from convicted speeders
27 Sep 2025 20:33 - 27 Sep 2025 20:35
It may be possible to remove the needle and reposition it. Some of the ZRX folk have done that. Evidently It is also possible to strengthen the magnets to improve accuracy.
You could also build a 10% reduction gear set to install between the cable and the speedometer.
Last edit: 27 Sep 2025 20:35 by TexasKZ.
- H1Vindicator
28 Sep 2025 15:29 - 28 Sep 2025 15:39
1997 zl600. partzilla. speedometer gear = 25T. pinion = 9T.
1986 zx600. partzilla. speedometer gear = 24T. pinion = 9T.
assuming a swap can be done. either the speedometer gear or the entire gearbox. the 24T will improve the accuracy by about 5%.
edit: 2005 ex500. speedo drive gear = 23T. pinion = 9T. if anything swaps. this would get you even closer.
Last edit: 28 Sep 2025 15:39 by H1Vindicator.
- ckahleer
28 Sep 2025 15:35I think that's the official line. The real reason is motorcycle manufactures want us to believe our bikes are faster than they really are.All vehicles read “high” not only to meet regulations but also to avoid litigation claims from convicted speeders
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
