kz1000p conversion 630/530
- GrzegorzSadoch
23 Sep 2025 00:01
Hello, I have a kz1000police and a chain drive 630 with sprockets of 15 - 35 teeth. I would like to change it to 530. What sizes of sprockets are best for this chain?
Re: kz1000p conversion 630/530
23 Sep 2025 00:42
I am using 18/46 on my build but the below calculator will let you pick what is best for you
Gearing Commander - Motorcycle Speed and Drive Train Calculator v7
23 Sep 2025 04:41
18/42
23 Sep 2025 04:49My bad - I have 17" wheels (best trust the calculator )18/42
- ThatGPzGuy
23 Sep 2025 05:23
I went to 18/42 and dropped my RPMs from 4,250 at 65MPH to 3,628.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
23 Sep 2025 06:17I went to 18/42 and dropped my RPMs from 4,250 at 65MPH to 3,628.
OP says he has 630 with sprockets of 15 - 35 teeth
The direct translation of that same gearing into 530 is 18/42. It won't drop rpm from where he is now. For that, he will need a smaller rear sprocket.
- GrzegorzSadoch
23 Sep 2025 07:03
Thank you very much, it's nice to be able to count on you.
- StreetfighterKz
23 Sep 2025 08:21
I thought Z1Enterprises had a 630-530 conversion article or calculator on their site somewhere. Might be worth a search.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
23 Sep 2025 08:51Doug the calculator I posted is really good and allows you to tailor tyre size and gear ratios to suit your individual needsI thought Z1Enterprises had a 630-530 conversion article or calculator on their site somewhere. Might be worth a search.
Later, Doug
23 Sep 2025 08:51 - 23 Sep 2025 08:53
6
30 chain/sprockets have 6
/8" link length (3/4")
5 30 chain/sprockets have 5 /8's link length
The 3 0 in the chain size means 3 /8" roller/sprocket width. In other words, the sprocket/roller width is the same for 630 and 530.
When converting from 630 to 530, first step is to assure the front sprocket is the same diameter, and that means adding 3 teeth size.
So, a 15T 630 sprocket, has the same diameter as 18T in 530. That's your baseline.
A ratio of 35/15 = 2.333
18T x 2.333 = 42T for the rear sprocket.
BTW, a 35T rear sprocket doesn't seem stock. Check the parts diagram on partzilla. Most 1000P bikes use a sprocket that's larger than this, thus the OEM gearing is lower.
Anyway, say the chain is 98 links, in 630.
98 x 6/8" between links = 73.5" long chain.
For 530, 73.5" / 5/8" per link = 117.6 links = 118 link chain
Last edit: 23 Sep 2025 08:53 by Nessism.
- StreetfighterKz
23 Sep 2025 09:54Yup. I’ve used it countless times for all my wheel swapping. Just thought something a little less intimidating (read: simpler) might be worth a look.Doug the calculator I posted is really good and allows you to tailor tyre size and gear ratios to suit your individual needs
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- ThatGPzGuy
24 Sep 2025 04:49I missed that. My gearing was 15/41 with 630 chain if my records are correct.I went to 18/42 and dropped my RPMs from 4,250 at 65MPH to 3,628.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
