Z650 B Rear Cush rubbers
- xbr500
30 Aug 2025 01:41
My usual sources do not seem to have rear cush rubbers for my KZ650 B 1978 (wire wheels).
I have tried CMSNL, ebay, Z-power.
Part number: 42014026
Does anyone know of a source or workaround?
- H1Vindicator
Re: Z650 B Rear Cush rubbers
30 Aug 2025 07:37 - 30 Aug 2025 07:40
several on ebaayy. alternative part. possibly the 80-83 550 or 81-83 650-csr. you'd need to do a visual comparison. if yours is salvageable. windshield/polyurethane adhesive might be used to secure it. I forget who did that.
Last edit: 30 Aug 2025 07:40 by H1Vindicator.
- kimchella
30 Aug 2025 10:45
As H1 says, there are some on EBay, you just have to make sure that they have the right locating rubber lugs. The spoked wheel has 3 round lugs.
Rich.
Rich.
KZ650B1 frame number 225
New Zealand
New Zealand
- Warren3200gt
30 Aug 2025 11:36 - 30 Aug 2025 11:37
Go ol skool. Cut up an old inner tube and locate over the sprocket carrier prongs. Bit of grease to ease titting into the cush drive rubbers location and the additional tube thickness will take up any loose play. They'll be good for another 50k
Last edit: 30 Aug 2025 11:37 by Warren3200gt.
30 Aug 2025 12:05
Old rubber, ain't new rubber.
I've had some of those cush hubs that had shrunken to the point that there was a fair bit of lash in the hub. Sort of like the rubber bumpers in the clutch hub, and/or, in the primary chain drive sprocket hub.
My preference is to replace those old rubbers with new. That removes the lash. Old inner tube strip wrapped around shunken rubber bits? Maybe. Better than a bunch of lash.
- H1Vindicator
01 Sep 2025 05:16
depending upon the condition. repair procedure that might work.
www.kzrider.com/forum/5-chassis/591045-kush-drive-differences
