Blocking off old front wheel speedometer cable connection
  • gordone
  • gordone's Avatar Topic Author
23 Aug 2025 14:41 - 23 Aug 2025 14:42
#916351
Hi,
I’ve converted to a modern speedometer with a proximity switch on the rear wheel, and I want to block off the cable connection on the front wheel to prevent water from getting in.I was thinking of using a round plate and a nut, or something similar.
I still have the rest of the old speedo cable, so maybe I can reuse the nut, fit a round plate inside it, and seal it with some liquid gasket?
Project:
Last edit: 23 Aug 2025 14:42 by gordone.
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Blocking off old front wheel speedometer cable connection
23 Aug 2025 15:03
#916352
Might be able to use some sort of vacuum nipple cap.  Get one that’s pretty rubbery and it should stretch over.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • gordone
24 Aug 2025 11:23
#916373
Thank you will look for correct size, measured it to be 11mm x 11mm.
Project:
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
  • TexasKZ
  • TexasKZ's Avatar
24 Aug 2025 20:20
#916386
You could remove the nut from an old speedometer cable and cut a small round out of gasket material.
  • gordone
24 Aug 2025 22:14
#916389
That was my orginal idea also, maybe that will be the most permanent solution…
Project:
