Z1 muffler fitment
  • danam
  • danam's Avatar Topic Author
Z1 muffler fitment
12 Aug 2025 10:00
#915852
Hi guys, I’m installing a Doremi replica 4 into 4 on my 75 Z1 im trying to tighten the rear mounting bolt but I find the upper muffler is making contact with the axel nut. I think I have done everything correctly as far I know. Any suggestions would be appreciated!
  • asphalt900
  • asphalt900's Avatar
Re: Z1 muffler fitment
12 Aug 2025 10:22
#915855
Happens all the time. Your frame A-arm looking rear peg holder has been knocked in. Just bend it back-out, 2X4 or whatever, tire iron chips the paint. A wooden dowel of some sort works fine.
  • danam
12 Aug 2025 10:36
#915858
this bike doesn't look Iike it's ever been down on that side. If it is pushed in I think I'll just shim the exhaust mount out.
  • hardrockminer
  • hardrockminer's Avatar
12 Aug 2025 17:22
#915864
If you're not a nut and bolt kind of guy just reverse the axle and put the nut on the chain side.
  • asphalt900
12 Aug 2025 23:21
#915876
The bike needn't to ever of been "down" for this to occur. A robust passenger getting on/off can cause it.
The following user(s) said Thank You: Mcdroid, Wookie58
