lower shock mount steel bushing measurements ?
  • H1Vindicator
  • H1Vindicator's Avatar Topic Author
03 Jul 2025 06:43 - 03 Jul 2025 06:44
#914339
looking for the measurements of the steel shock damper bushings on a 70s 650B/C/D or 750B. part # 45016-008. the lower shock mount bolts are M10 x 35. that's all I know. ha ha.
Last edit: 03 Jul 2025 06:44 by H1Vindicator.
  • kimchella
  • kimchella's Avatar
Re: lower shock mount steel bushing measurements ?
04 Jul 2025 01:24
#914354
Hi, I can measure for you tomorrow if no one else does it first 👍
Rich.
KZ650B1 frame number 225
  • kimchella
04 Jul 2025 15:07
#914377
Hi, the metal bush is-
15.1 mm ext diameter x 20.15 mm wide.
Hope this helps,
Rich.
The following user(s) said Thank You: H1Vindicator, MFP-Joe
  • H1Vindicator
06 Jul 2025 09:14
#914405
thanks. I went ahead and ordered some 70s rubber shock dampers. guessing that my bushings will fit. the lower shock mounts on my motorcycle don't have a separate part number for the dampers and bushings, whereas some of the 70s models do.
The following user(s) said Thank You: kimchella
