Anyone make bearings to fit a kz axel into a Harley rim ?
- kawsakiman
01 Jun 2025 17:11
I have a 250 spoked rim and tire for a dyna, wondering if anyone makes bearings so I can swap it onto my Clubman swingarm ?
- StreetfighterKz
Re: Anyone make bearings to fit a kz axel into a Harley rim ?
01 Jun 2025 17:27
What size are the ID of the HD bearings: 1in? If so you could probably make some top-hat spacers with the Kz axle OD as the ID and the HD ID as the OD. Make sense?
Or you can look at NakedFun’s build. Pretty sure he used HD hubs with a 20mm axle.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- z1kzonly
02 Jun 2025 08:13
Hey, Your not in an old folks home yet?
Come on lets go look at some! We'll ask if we can park motorcycles out back in the Shed!
Hope all is well Steve! Last time? You were getting Surgery.
New HD might have a metric hub? Are the new HD's still 3/4" axle?
I deal with Buffalo Bearings here. They have specialty bearings,
I put 20mm I.D. bearings in a front Z1 wheel hub for a 20mm rear axle to use. Uncommon bearing.
Or Start with my 18" x 5.5" x 40 spoke Harley wheel that is on fbmarketplace for $250 with new 530 sprocket / new 10" disc.
Marty
Marty
- asphalt900
03 Jun 2025 05:52
Marty!! You're way too Young to be confined in an ole folks home!! Hope You're doing Fine, Clay
- kawsakiman
03 Jun 2025 12:58
Beautiful rim , too bad it is an 18.
16 and I would be heading there by now.
