Centre stand for a 1976 kz 750 b twin
  • Macils
  • Macils's Avatar Topic Author
15 May 2025 09:57 - 15 May 2025 10:33
#912458
Hi.  I need a centre stand for a 1976 kz750B twin, will a centre stand for a 1982 kz 750E, I know one is a twin and the other a four,but that's  all I can find in  Ireland. Thanks in advance  if anyone can help.
Last edit: 15 May 2025 10:33 by Macils. Reason: Spelling mistake
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Centre stand for a 1976 kz 750 b twin
15 May 2025 11:43
#912459
According to CMNSL the part number is unique to 750 twin 76-79 B1,B2,B3,B4
The following user(s) said Thank You: Macils
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
15 May 2025 12:43
#912461
Partzilla indicates the same but does list 2 different part nums.
34019-016 not available
34011-039 sign in to see price
The Kawasaki site shows the same 2 part numbers with the second one (039) showing it began on frame num 000760 and continued through the entire run of the 750 twins, at least that is how I read it.
I do not have one to measure for you, but would/hope another member here can do so for you. I do not know but maybe if you learned what the stock one is (size height width etc you might be able to find another one that meets those needs.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
