Throotle wire routing - KZ 750
  • gordone
  • gordone's Avatar Topic Author
14 May 2025 10:21 - 14 May 2025 10:22
#912428
Hi,
bike: 1981 KZ650-D4
somebody has picture of the throotle cable routing?
Project:
Last edit: 14 May 2025 10:22 by gordone.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Throotle wire routing - KZ 750
14 May 2025 12:49
#912440
Do not know if this will be of help or not, but I have always had the wire cables run down the left hand side of the main center tube and the throttle cable(s) run down the right hand side of the center tube. A question I would ask is are you using carbs that have single cable or dual cables (push/pull)?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • gordone
14 May 2025 21:44
#912452
Two cables for throotle, think I found a good routing yesterday.
thnx
Project:
