Engine brackets
  • Formula264
  • Formula264's Avatar Topic Author
Engine brackets
08 May 2025 14:30
#912266
I need to source the triangular engine mounts for the 78' frame are those available new or do I search out as used? Thanks for any info. Posted more pictures in the projects topic of the progress.
  • TexasKZ
  • TexasKZ's Avatar
Re: Engine brackets
08 May 2025 14:39
#912268
A 1978 what?
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Engine brackets
08 May 2025 16:01
#912269
Which plates, I thought the motor was in ????
  • Formula264
Re: Engine brackets
08 May 2025 16:48
#912270
78 KZ1000
  • Formula264
Re: Engine brackets
08 May 2025 16:49
#912271
The triangular ones. My brother used his off his frame to mock up the install...he won't let me have them😜
  • Formula264
Re: Engine brackets
08 May 2025 16:54
#912272
The two rear lower ones and the front upper.
  • sf4t7
  • sf4t7's Avatar
Re: Engine brackets
08 May 2025 17:08
#912273
You could just make your own, you've got his to use for patterns.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • Formula264
Re: Engine brackets
08 May 2025 17:42
#912274
True...if we must.
  • sf4t7
  • sf4t7's Avatar
Re: Engine brackets
08 May 2025 19:17
#912278
They're pretty simple shapes, I'm thinking it's probably quicker to just make some instead of spending time and effort searching and ordering...
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: Wookie58, Formula264
  • Formula264
Re: Engine brackets
09 May 2025 12:50
#912291
I found them! I figured I would lighten my brothers fabrication load, he can spend that time on making my headlight mounts and rear sets..
