1977 kz1000 stock brake refresh
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 1977 kz1000 stock brake refresh
25 Apr 2025 13:39
#911737
I some rare cases i cooked the calipers in hot oil to get the pistons free, heat is your friend sometimes.....
  • sf4t7
  • sf4t7's Avatar
25 Apr 2025 16:29 - 25 Apr 2025 20:23
#911741
I managed to get the pistons to move by heating the caliper body with a heat gun and then applying brake cleaner spray to the middle of the piston surface to cool it relative to the caliper bore.  It's probably not seized to the caliper bore surface, but held tight by the seal inside.  Penetrating oil like PB Blaster and some heat can help.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 25 Apr 2025 20:23 by sf4t7.
The following user(s) said Thank You: Nessism, MFP-Joe, Wookie58
