bore size for rear master cylinder
  • rlcarter
  • rlcarter's Avatar Topic Author
24 Mar 2025 16:50
#910483
need help ;  I posted a question about bore size on rear master cylinder, about a month ago and I got no replies, not sure if I did something wrong posting it . if anyone could help me I would appreciate it I am working on a 1980 kz1000G.
1980 KZ1000 G w/carbs..
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: bore size for rear master cylinder
24 Mar 2025 17:19
#910485
The bore size is 1/2 inch AFAIK, should be cast in the rear MC body......
The following user(s) said Thank You: rlcarter, Gdizard
  • rlcarter
24 Mar 2025 19:43 - 24 Mar 2025 19:44
#910490
 the bore is 5/8 but I purchased a new master cylinder for a newer bike . it mounted up alright but it has a smaller bore now I'm having trouble getting it to pump up i have bled the system several times my question was would the smaller bore and smaller reservoir cause it not to pump up
Last edit: 24 Mar 2025 19:44 by rlcarter.
  • Nessism
  • Nessism's Avatar
  • Away
24 Mar 2025 20:27
#910492
Wow!  5/8 is huge for a rear master.  The J series 1000's uses a 14mm master.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
25 Mar 2025 00:14 - 25 Mar 2025 03:07
#910495
Not sure what you mean by "pump up", are you saying that the system is bled but doesn't build pressure when pushing the pedal ? if you push the pedal several times quickly does it build pressure ? it is possible the if the master/calliper hydraulic ratio is way off that a single push of the pedal doesn't displace enough fluid to apply pressure in the calliper !
A "braided" line may help as there will be less "expansion" in the hose than the stock rubber item which steals pressure from the calliper.
Last edit: 25 Mar 2025 03:07 by Wookie58.
  • rlcarter
25 Mar 2025 08:45
#910515
the new master that I put on is a smaller bore  I suppose the ratio could be off but I have tried pushing the pedal several times quickly , still no pressure .I took the line loose at the caliper and pushed the pedal, it is pushing fluid.i do have an after market line on it which I had when the original 5/8 master was on and it worked.i am gonna double check for leaks  but in the mean time try to find a rebuild kit for the 5/8 master  thanks for replying I will see what I find and let you know
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
25 Mar 2025 09:43
#910518
Is the replacement cylinder "after market" - you could try disconnecting the line from the master and inserting a 10x1.25 bolt then see if the master actually produces any pressure (do it carefully or you could flip the seals) worth a try before you keep throwing money at it ?
  • rlcarter
25 Mar 2025 14:53
#910529
yes it is after market  I will try and block it off .thanks wookie
