Tire Questions
  • JR
  • JR's Avatar Topic Author
Tire Questions
10 Mar 2025 08:42 - 10 Mar 2025 08:43
#909894
I have Bridgestone Spitfires on front and rear. The front is in good shape but the rear has a little bit of sidewall cracking and I'm looking at it and thinking I should replace it.
However. I cant find a Bridgestone Spitfire and I dont think they even exist any more. What is the thinking re putting a different brand tire on the rear?
or perhaps a Bridgestone Battlax on the rear?
Also thinking maybe a set front and rear Shinko. Japanese, make in Korea. Anyone  running them on a 750/4 ?
Last edit: 10 Mar 2025 08:43 by JR.
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Tire Questions
10 Mar 2025 08:49
#909896
Replace the pair, both front and back. As the back one  wears fastest and is old enough to split I bet the front is ancient also.
What's the date code on the front tire?
When riding, if a tire is going to let go I'd rather it be the rear over the front.!
The following user(s) said Thank You: JR
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Tire Questions
10 Mar 2025 09:03 - 10 Mar 2025 09:04
#909897
Agree ref replacing as a pair, if you like the spitfires they are available by the looks of it ?
Bridgestone Spitfire S11
Last edit: 10 Mar 2025 09:04 by Wookie58.
  • JR
Re: Tire Questions
10 Mar 2025 09:28
#909899
Date code on the front 1220. So week 12 2020. Rear also coded for sometime in 2020.
i do like the spitfires and have had several sets over the last 20 + years . Possible that  they are no longer available just in Canada.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Tire Questions
10 Mar 2025 09:35
#909900
Maybe I should have looked where you are before posting a North American link
  • sf4t7
  • sf4t7's Avatar
Re: Tire Questions
10 Mar 2025 09:36
#909901
I've got Shinko 230's on my Z1.  Very happy with them, good grip dry or wet roads.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: JR, SWest
  • kimchella
  • kimchella's Avatar
Re: Tire Questions
10 Mar 2025 09:40
#909902
Totally agree with Warren, replace both as a pair,  I have had old tyres that look good fail, and at speed it is not fun. I am using Bridgestone Battlaxe tyres which are a decent tyre..
Rich.
KZ650B1 frame number 225
New Zealand
  • Nessism
  • Nessism's Avatar
Re: Tire Questions
10 Mar 2025 12:53
#909905
Pretty sure the Spitfire was discontinued.  Shinko 230 are cheap, and they stick well, but they wear fast.  A good choice for a bike that doesn't see a bunch of miles.
120/90-18 rear
100/90-19 front
  • JR
Re: Tire Questions
10 Mar 2025 13:26
#909906
Just back home from a visit to my local small motorcycle store and can confirm Spitfires discontinued.
Had a good chat and settled on a pair of Shinko 230 Tour Masters. I've been a regular there for years and got a very good price that includes install. If I have to change them at 3 or 4 years thats ok. Still a good deal. I only do about 3000 km/ year but the extreme weather here is rough on tires as the bike is parked outdoor 12 months a year.
it will be a couple more weeks before i'm back on the road. Still a bit of snow about and when that goes we'll have left over grit and crud in the corners.
thanks All
The following user(s) said Thank You: Nessism, sf4t7, Wookie58
