Adjusting odometer milage
  • ckahleer
  • ckahleer's Avatar Topic Author
03 Dec 2024 10:38
#906610
Sometimes I need to replace the speedometer when referbushing older bikes. I usually get a used speedometer off e-bay. Is there a better way to adjust odometer mileage than using an electric drill and letting it run, sometimes for days. Are there small, reversible motors that run faster than a drill? It needs be able to both remove or add miles.
97 ZL600
94 VF750c
94 KE100
82 KZ305
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Adjusting odometer milage
03 Dec 2024 13:06
#906613
I'm not sure running the mechanism backwards at that speed is a good idea
