Repairing or cleaning inside of gauge glass? How to re-ring?
- chopper1963
20 Nov 2024 06:37
Have we ever figured out a way to get that ring off and BACK ON that holds the Kawasaki gauges together like the one on the GPz550 I am working on now? The inside of the glass has some kind of condensation on it that won't go away.
Re: Repairing or cleaning inside of gauge glass? How to re-ring?
20 Nov 2024 07:55
My rebuild thread shows how to open the gauges. I think it's somewhere near page 3 or so.
The following user(s) said Thank You: chopper1963
- chopper1963
20 Nov 2024 09:54
Thanks. That is amazing rebuild!
So did you use the same screwdriver to put the ring back on, or how did you get it re-crimped back on?
20 Nov 2024 10:18
You can use a screwdriver, or better, a punch and hammer, to push the lip back down.
Pry slowly, a little at a time, as you work around the gauge. It will take several revolutions around before the lip is suitably opened. Same when closing; go slow, a little at a time, as you work around.
- chopper1963
20 Nov 2024 13:19
What is the ring made from? Tin? Would heat help, also?
- Nerdy
20 Nov 2024 16:24
I think if you apply enough heat to modify the properties of almost any metal, you'll run the risk of damaging the gauge face and/or internals
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- gd4now
- Denco where did you go?
20 Nov 2024 17:06
Agree no heat is needed. I know I am old but I think for some reason I have see some one on some on line site where a wheel was use to push the ring back done tight but I can not find what I am thinking of sorry This getting old is not for sissies!
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
20 Nov 2024 19:39This is an understatement. The metal needs to be red hot in order to ease bending, and the plastic gauge housing would melt into a puddleI think if you apply enough heat to modify the properties of almost any metal, you'll run the risk of damaging the gauge face and/or internals
