How much preemptive brake work
  • kylemontmont
  • kylemontmont's Avatar Topic Author
11 Oct 2024 15:20
#905018
I’m trying to decided how much brake work I should do on my late grandfather’s 83 kz440 ltd 8500 miles that hasn’t been register in 15 years.  I have it running and the brakes worked fine when I got it up to 20mph on grass,  I know I at least need to flush the brake fluid, but I’m deciding if I should preemptively do more than that, like rebuilding the caliper, replacing the pads, and maybe replacing the brake lines.
Pads probably aren’t anywhere near worn out, but I imagine the pad material has gotten better enough to be worth putting some new ones on.  For everything’s else my concern is just rubber age.
Old bike barn is where I was looking at for the pads and caliper rebuild kit.
Any advice welcome, thanks
1983 KZ440 LTD
Brevard County, FL
  • Nessism
  • Nessism's Avatar
  • Away
Re: How much preemptive brake work
11 Oct 2024 15:46
#905019
I would do a full system tear down and clean out.  There is a very high likelihood of cruddy brown brake fluid chunks in the system.  You can reassemble using the old seals, but replacing them with OEM parts is highly recommended.  Aftermarket brake parts are risky, particularly K&L.  Then, use new brake lines.  For pads, you can reuse them if they are working well.  Or replace them.  Disc pads are only about $20 a set anyway.
The following user(s) said Thank You: kylemontmont
  • H1Vindicator
  • H1Vindicator's Avatar
11 Oct 2024 17:14 - 12 Oct 2024 08:01
#905022
Replace the rear brake shoes.  if not and the rear wheel locks, you have been warned. For the front and rear be sure to use a brake grease, applied sparingly at the appropriate lube points. don't get any on the braking surfaces.
edit. get new, not nos. nos is new but old, and old is the problem.
Last edit: 12 Oct 2024 08:01 by H1Vindicator.
The following user(s) said Thank You: sf4t7, kylemontmont
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
11 Oct 2024 17:35
#905026
On old rear wheel drum break shoes the brake pads can come off !!!
The glue is getting old and brittle, so be carefull and inspect them !!!
  • H1Vindicator
11 Oct 2024 17:40
#905028
There's nothing to inspect !!! replace 'em !!!
  • kylemontmont
14 Oct 2024 20:21
#905117
Are there new OEM parts? I haven't come across anything that says it's OEM, just nondescript caliper rebuild kits and unbranded pads mainly.  I've linked below the old bike barn rebuild kit I was looking at.
oldbikebarn.com/collections/kz440/produc...-caliper-rebuild-kit
1983 KZ440 LTD
Brevard County, FL
  • kylemontmont
14 Oct 2024 20:23
#905118
Good to know, I had not considered how much worse pad failure would be with a drum brake.
1983 KZ440 LTD
Brevard County, FL
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
15 Oct 2024 08:40
#905140
We get most of our brake parts from brakecrafters.com including stainless steel caliper pistons.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • Nessism
  • Nessism's Avatar
  • Away
15 Oct 2024 12:00
#905150
Partzilla.com
