- Thank you received: 1
KZ200 front brake O-ring size
- RossH
12 Aug 2024 15:47 - 12 Aug 2024 18:30 #903170
by RossH
KZ200 front brake O-ring size was created by RossH
Hello,
I need to replace the 4 o-rings on the two bolts that hold the front brake caliper together on my '78 KZ200. Does anyone know the specific size of these o-rings? They are number 3 in the linked diagram: www.partzilla.com/catalog/kawasaki/motor...kz200-a1/front-brake . I do not see the dimensions listed in either the factory manual or the Haynes manual.
Thanks in advance,
Ross
Thanks in advance,
Ross
Last edit: 12 Aug 2024 18:30 by RossH.
- gd4now
- Denco where did you go?
- Thank you received: 678
13 Aug 2024 10:17 #903198
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic KZ200 front brake O-ring size
Sorry I will not be of any help on the size of the o-rings. But I did do some looking at several different part list sites and the part number shown (43063-001) when searched for brings up a bracket that holds the brake line but no mention of the o-rings? The bracket is not shown in the parts pics?
1977 KZ650 B1
- RossH
13 Aug 2024 16:27 #903219
by RossH
Replied by RossH on topic KZ200 front brake O-ring size
Yeah, I found that odd, too. They call the o-rings a brake hose bracket, but that's clearly not what they are. They don't list the o-rings.
- Thank you received: 1646
14 Aug 2024 08:13 #903253
by martin_csr
Replied by martin_csr on topic KZ200 front brake O-ring size
You're probably going to have to remove the bolts and measure some stuff. Digital calipers might be handy.
A metric nitrile or viton o-ring kit might have a size that will work. Viton is probably preferable.
ps: I use Permatex ultra brake caliper grease on stuff like this. I don't think it comes in the little packets any more. A small tube is listed on their site instead.
