Center Stand
- tomsbadkz
Center Stand
14 Jul 2024 14:20
Just kind of curious why someone would cut off center stand bracket so no center stand can be used to put an exhaust on that has to be completely removed just to change the oil.
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
Re: Center Stand
14 Jul 2024 14:30
Would it not be easier to use a paddock stand than mess about re-fitting a main stand for this purpose (my brackets are still in place as this is where my lift picks up from)
Re: Center Stand
14 Jul 2024 14:37 - 14 Jul 2024 14:43
Because they can or are not the brightest candle on the birthday cake.
See a lot of stupid repairs, fixes, mods, upgrades, conversions, stupidities of so called wanna be mechanics @ Youtube channel "Just Rolled In"
Last edit: 14 Jul 2024 14:43 by Scirocco.
- willemZ900
- Z1B 4 ever
Re: Center Stand
15 Jul 2024 03:52
I use the centerstand only in wintertime when the Z is sleeping or when i want to change tires. The paddock stand is for oil change or chain cleening/ajustement. I dont understatement People Who cut of the brackets.
- tomsbadkz
Re: Center Stand
15 Jul 2024 06:01
Yea, i generally use my lift for oil changes and such, but i like having original stand. If id have issue along the road and need wheel off the ground for a broken chain, etc. Thanks guys. Just wanted to ask others cause the guy i bought the bike from had a shit fit cause i took off the exhaust he had on it. Like i said, couldn't even change the oil without total removal.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: Center Stand
17 Jul 2024 08:50
I have a full collection of paddock stands, and I cut off my center stand lugs to clear the exhaust on my Suzuki. I have to drop the exhaust anyway to change the oil. To me, it's no big deal
- Cra-z1
Re: Center Stand
17 Jul 2024 15:58
Then you got the guys who cut off everything to save weight
- tomsbadkz
Re: Center Stand
17 Jul 2024 16:02
Yes , i'm sure that will make a difference on a six hundred pound motorcycle
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- sf4t7
Re: Center Stand
17 Jul 2024 17:19 - 17 Jul 2024 17:20
My center stand became a shop tool 40 years ago when installing my Kerker (now it's installed only for oil and filter, tire, and chain / sprocket changes). Didn't notice any performance gains from the slight weight reduction
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 17 Jul 2024 17:20 by sf4t7.
- Kelly E
Re: Center Stand
17 Jul 2024 17:31
I installed a center stand on my 77' KZ 1000LTD because it didn't come with one but has the mounting brackets. It had the dealer mounted Kerker that was trashed. I replaced it with a stainless steel Delkevik that allows you to use a center stand.
No center stand on a chain driven bike kinda sucks.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
- tomsbadkz
Re: Center Stand
17 Jul 2024 17:37
Yeah, I kept the brackets on my pro street KZ and can just slide the bolts in and use the centerstand at the house if I need it. Its not designed for long rides. Race gas mix and big block cylinder. Doesnt like hot summer days much.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
Re: Center Stand
18 Jul 2024 01:01 - 18 Jul 2024 01:02
I guess it also depends how you use your bike. I can't speak for my KZ (yet) but many other bikes I have ridden had a tendency to "ground" the main stand on left hand bends which can be exciting
I guess this isn't an issue if your bike is set up for straight line performance
PS: real nice GPZ
PS: real nice GPZ
Last edit: 18 Jul 2024 01:02 by Wookie58.
