- Thank you received: 16
KZ1000 A3A MarkII front brakes
- Bobf
- KZ1000A3A
EKKAWI
1976 KZ400D, 1977 KZ1000A1, 1976 KH400, 1979 XS400, 1980 KZ550A, 1980 KZ750E, 1983 GPZ550,1979 KZ1000B LTD, 1986 ZG1000 Concours,1982 XS650 Turbo,KZ1000C, KZ1000P,1978 KZ650C (×2),2003 BMW R1150RT
2014 BMW R1200RT (Current ride)
1971 Norton 750 Commando
1979 KZ1000A3A MKII (Present project)
- Thank you received: 1918
- Thank you received: 1088
- Thank you received: 2224
www.partzilla.com/product/kawasaki/41080...13c2301b2ed20f3ba59a
Are these close enough? Likely much cheaper than oem.
japan.webike.net/products/21799350.html
Several choices here, just be absolutely sure that the ones you look at are in fact for the1979 - 80 MKll, GPz, et cetera
japan.webike.net/KAWASAKI/Z1000+MkII+KZ1...+Rotor/6284/1012/mc/
- Bobf
- KZ1000A3A
Thank you for the feedback!
Bob F.
EKKAWI
- Bobf
- KZ1000A3A
Looked at these. Hadn't checked out Japan webike. Looks like their prices may be a bit more than I'm willing to spend. Although, they do have some pretty cool stuff! Trying to keep the front end parts cost within my budget. (I know....there is no such thing as a "Budget" where old motorcycle restorations are involved....)If you need the 41080-1022, Partilla says they ship in 3-4 days. Maybe they lie. Could be worth a call.
Much thanks for the input!
Bob F.
EKKAWI
- Bobf
- KZ1000A3A
Much thanks!!Mounting face to mounting face 105mm. Outside to outside of rotor face is 114.85 +-
EKKAWI
- DOHC
- Those Doe-Hawks really go!
- Thank you received: 545
Partzilla shows this part was used on the '79 and '80 K1000A (MK2), KZ1000B (LTD), KZ1000C (police), KZ1000D3 ('80 Z1R), and KZ1000G1 ('80 classic). It was also used on the 1980 KZ650-E1, F1, and KZ750-G1.
Put that number into Ebay, and you get many hits.
This one is $63: ebay.com/itm/265391659725
This one is $30: ebay.com/itm/333610351246
This one is $35: ebay.com/itm/402772513561
The original rotors for you bike are not that rare, they came on all the KZ1000 models for '79 and '80. Swapping the forks, wheel, brakes, and rotors from a 750 is going to cost you a lot more money and time than just waiting a little while for a decent set of the correct 41080-1022 part to show up on ebay.
My dad's '74 Z1
'00 ZRX1100
Unless you have a 750 donor bike already on hand, those rotors are bound to be cheaper and MUCH easier.I'm aware of the different thicknesses. Was looking for the total width for rotors, outer side to outer side when mounted on the wheel. Trying to determine if I could use a 750E front wheel with current MK2 calipers. I understand there will be some engineering involved. If nothing else, I will likely use outer 750E fork tubes and calipers along with the 750E front wheel. Wheel is the same size so ride geometry shouldn't be compromised - and end up with better brakes, albeit not totally stock looking.
Bob F.
- gd4now
- Denco where did you go?
- Thank you received: 431
E
41080-1022
Model (13):
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D3 (Z1R) (1980)
KZ1000-G1 (Classic) (1980)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ750-G1 (LTD II) (1980)
F
41080-1022
Model (13):
KZ650-F1 (1980)
There is a post here that has more info on the disks to add to the discussion, or confuse us more?
kzrider.com/forum/5-chassis/576483-re-fr...-1977-kz-650-#576695
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- DOHC
The comment about 8 vs 9 rivets is interesting. It looks like the second eBay link I posted is probably not correct for the kz1000 (only 8 rivets), but the first and third links look like they are probably correct.
My dad's '74 Z1
'00 ZRX1100
