KZ1000 A3A MarkII front brakes
- Bobf
- KZ1000A3A
21 Jun 2024 09:09
Front brake conundrum. Trying to keep my MK2 front looking close to stock and have badly worn rotors. Replacement OEM rotors are nonexistent with aftermarket prohibitively priced. I can source a KZ750E (1980) model 19-inch front wheel with rotors on e-bay that has similar looks to the stock MK2. Rotor diameter is 226mm vs MK2 250mm; so that will require caliper mounting adjustment. Wondering if anyone has experience and or come up with a solution/alternative? Width of the wheel assembly for the MK2 from outside L-rotor surface to outside R-rotor surface is 125mm (4.92 inches). Don't know what the KZ750E width is. Anyone have the measurements? Much thanks in advance!!
EKKAWI
1976 KZ400D, 1977 KZ1000A1, 1976 KH400, 1979 XS400, 1980 KZ550A, 1980 KZ750E, 1983 GPZ550,1979 KZ1000B LTD, 1986 ZG1000 Concours,1982 XS650 Turbo,KZ1000C, KZ1000P,1978 KZ650C (×2),2003 BMW R1150RT
2014 BMW R1200RT (Current ride)
1971 Norton 750 Commando
1979 KZ1000A3A MKII (Present project)
Re: KZ1000 A3A MarkII front brakes
21 Jun 2024 10:54
Yes, I have an E1 front wheel waiting on fresh bearings I can measure for you later this evening
The following user(s) said Thank You: Bobf
21 Jun 2024 13:11
I would guess the rotors would be the same size for any big bike (1000 cc) with dual rotors. Are you aware the rotors on a dual rotor bike are thinner than on a single rotor bike?
21 Jun 2024 13:25 - 21 Jun 2024 13:39
If you need the 41080-1022, Partilla says they ship in 3-4 days. Maybe they lie. Could be worth a call.
www.partzilla.com/product/kawasaki/41080...13c2301b2ed20f3ba59a
Are these close enough? Likely much cheaper than oem.
japan.webike.net/products/21799350.html
Several choices here, just be absolutely sure that the ones you look at are in fact for the1979 - 80 MKll, GPz, et cetera
japan.webike.net/KAWASAKI/Z1000+MkII+KZ1...+Rotor/6284/1012/mc/
Last edit: 21 Jun 2024 13:39 by TexasKZ.
- Bobf
- KZ1000A3A
21 Jun 2024 16:11
I'm aware of the different thicknesses. Was looking for the total width for rotors, outer side to outer side when mounted on the wheel. Trying to determine if I could use a 750E front wheel with current MK2 calipers. I understand there will be some engineering involved. If nothing else, I will likely use outer 750E fork tubes and calipers along with the 750E front wheel. Wheel is the same size so ride geometry shouldn't be compromised - and end up with better brakes, albeit not totally stock looking.
Thank you for the feedback!
Bob F.
Bob F.
EKKAWI
- Bobf
- KZ1000A3A
21 Jun 2024 16:15Looked at these. Hadn't checked out Japan webike. Looks like their prices may be a bit more than I'm willing to spend. Although, they do have some pretty cool stuff! Trying to keep the front end parts cost within my budget. (I know....there is no such thing as a "Budget" where old motorcycle restorations are involved....)If you need the 41080-1022, Partilla says they ship in 3-4 days. Maybe they lie. Could be worth a call.
Much thanks for the input!
Bob F.
EKKAWI
21 Jun 2024 19:53
Mounting face to mounting face 105mm. Outside to outside of rotor face is 114.85 +-
- Bobf
- KZ1000A3A
21 Jun 2024 20:43Much thanks!!Mounting face to mounting face 105mm. Outside to outside of rotor face is 114.85 +-
EKKAWI
- DOHC
- Those Doe-Hawks really go!
22 Jun 2024 09:05
Looking at the part number for the front rotors for the KZ1000 A3 MarkII, the Partzilla diagrams say it is 41080-1022.
Partzilla shows this part was used on the '79 and '80 K1000A (MK2), KZ1000B (LTD), KZ1000C (police), KZ1000D3 ('80 Z1R), and KZ1000G1 ('80 classic). It was also used on the 1980 KZ650-E1, F1, and KZ750-G1.
Put that number into Ebay, and you get many hits.
This one is $63: ebay.com/itm/265391659725
This one is $30: ebay.com/itm/333610351246
This one is $35: ebay.com/itm/402772513561
The original rotors for you bike are not that rare, they came on all the KZ1000 models for '79 and '80. Swapping the forks, wheel, brakes, and rotors from a 750 is going to cost you a lot more money and time than just waiting a little while for a decent set of the correct 41080-1022 part to show up on ebay.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
22 Jun 2024 10:29Unless you have a 750 donor bike already on hand, those rotors are bound to be cheaper and MUCH easier.I'm aware of the different thicknesses. Was looking for the total width for rotors, outer side to outer side when mounted on the wheel. Trying to determine if I could use a 750E front wheel with current MK2 calipers. I understand there will be some engineering involved. If nothing else, I will likely use outer 750E fork tubes and calipers along with the 750E front wheel. Wheel is the same size so ride geometry shouldn't be compromised - and end up with better brakes, albeit not totally stock looking.
Bob F.
- gd4now
- Denco where did you go?
22 Jun 2024 10:41
I agree with DOHC that part number was used on the bikes he indicated. I the past I pulled down from the Kawasaki site when it listed what bikes/models a part # was used on. This is what was shown for the KZ650 E1 and F1.
E
41080-1022
Model (13):
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D3 (Z1R) (1980)
KZ1000-G1 (Classic) (1980)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ750-G1 (LTD II) (1980)
F
41080-1022
Model (13):
KZ650-F1 (1980)
There is a post here that has more info on the disks to add to the discussion, or confuse us more?
kzrider.com/forum/5-chassis/576483-re-fr...-1977-kz-650-#576695
E
41080-1022
Model (13):
KZ650-F1 (1980)
F
41080-1022
Model (13):
KZ650-F1 (1980)
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- DOHC
22 Jun 2024 11:02 - 22 Jun 2024 12:34There is a post here that has more info on the disks to add to the discussion, or confuse us more?
The comment about 8 vs 9 rivets is interesting. It looks like the second eBay link I posted is probably not correct for the kz1000 (only 8 rivets), but the first and third links look like they are probably correct.
'78 Z1-R in blue
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 22 Jun 2024 12:34 by DOHC.
