Chain adjuster
  • Formula264
  • Formula264's Avatar Topic Author
Chain adjuster
20 May 2024 13:00
#899391
I have decided to use the Zephyr 1100 swingarm on my 78 KZ build . I am in need of the axle, bushings/bearings and the chain adjusters. Are Zephyr 750 components compatible? Are the ZRX components compatible or will I have to source all used through eBay. Thanks for any info, Cody
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Chain adjuster
20 May 2024 13:04
#899392
If you look at Partzilla or CMNSL you can compare part numbers and it will tell you if they are common to other models
The following user(s) said Thank You: Formula264
  • TexasKZ
  • TexasKZ's Avatar
Re: Chain adjuster
20 May 2024 14:28
#899399
When you go to Partzilla and click on the part number, you will be able to see a Fitment chart showing every model that used that specific part. For example, the Zephyr 1100 rear axle was used only on the 1100 Zephyr and the ZX10.
www.partzilla.com/product/kawasaki/41068...65736108112fae38ccf1
